8 Replies Latest reply on Dec 14, 2009 1:17 PM by Pietro Estrada
    Array assign Buttons actions
    Pietro Estrada
      //AS BEGINS
      var productList:Array = Array("diabeoff", "cholestoff", "inulina", "colageno", "power", "castoff", "dieta", "miel", "extrapower");
      var numberOfProducts:Number = productList.length;
      function enableButtons(productList:Array, numberOfProducts:Number):Void {
           for (i=0; i<numberOfProducts; i++) {
                productList[i] = "."+productList[i];
                pressedButton = this.productos+productList[i];
                pressedButton.onPress = function():Void  {
                     trace(pressedButton);
      enableButtons(productList,numberOfProducts);
      //AS ENDS
      Anyone can sayme why this is not working?
      the actions are not assigning to the buttons
        • 1. Re: Array assign Buttons actions
          your array elements are strings.  use array notation to convert to objects.  so, if those corresponding objects are children of this.productos, use:
          Pietro Estrada wrote:
          //AS BEGINS
                    pressedButton = this.productos[productList[i]];
          //AS ENDS
          • 2. Re: Array assign Buttons actions
            I suspect the problem lies in whatever you are trying to do between these lines...
            What are the buttons' names and what is "this.productos"
            • 3. Re: Array assign Buttons actions
              Pietro Estrada Level 1
              Products is a Movie on Canvans with that instance name...
              the name of the buttons are... the names inside the array =)
              • 4. Re: Array assign Buttons actions
                how can I use array notation?
                • 5. Re: Array assign Buttons actions
                  Based on what you just described, kGlad's solution should be what you need.
                  • 6. Re: Array assign Buttons actions
                    yes but how I use Array notation?? how I change the sintaxys?
                    =S
                    tansk for the help I'm reading but I dont find about AS, only AJAX, PHP, JAVA
                    • 7. Re: Array assign Buttons actions
                      He edited your code for that already...  The following line uses the array syntax...
                      The basics of this syntax in that a String value is treated as an instance name when you include it in the brackets as shown...
                      this["some_object_name_as_a_String"]
                      this.productos["buttonname"];
                      etc...
                      The array syntax is a very useful tool to get into your toolbox.
                      • 8. Re: Array assign Buttons actions
                        FINAL PRODUCT
                        //AS BEGINS
                        //AS ENDS
