0 Replies Latest reply on Dec 14, 2009 12:09 PM by Peter Farland
    [svn:fx-trunk] 12912: With TLF 571 checked in we can now revert the MXML 2009 changes for how the id language attribute is processed .
    Peter Farland Level 3
      Revision: 12912
      Revision: 12912
      Author:   pfarland@adobe.com
      Date:     2009-12-14 12:08:35 -0800 (Mon, 14 Dec 2009)
      Log Message:
      With TLF 571 checked in we can now revert the MXML 2009 changes for how the id language attribute is processed.
      An unqualified id property will no longer be seen as a setter for a normal public, writable, non-static "id" property - which matches Flex 3 behavior.
      As in earlier versions of Flex, the mechanism to retain MXML id attribute information at runtime is to implement mx.core.IMXMLObject. The compiler will generate a call to the intialized() method and pass in the id information.
      Note: One exception to this rule seems to be UIComponent which instead get id attribute information via mx.core.IDeferredInstantiationUIComponent (although there seems to be a TODO in the codebase to remove this mechanism and thus should not be relied on by third parties).
      QE notes: Please add tests for the TLF id property on flow elements (div, span, p, etc).
      Doc notes: Please check that we have not documented
      Bugs: N/A
      Reviewer: Paul
      Tests run: Checkintests, local test cases.
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Type.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IID.as
