1 Reply Latest reply on Dec 15, 2009 5:45 AM by Ned Murphy
    photo slideshow in flash with text
    gvasudha
      I want to create a flash video that contains a photo slideshow,like in this link
      http://www.purdue.edu/
      I am not knowing where to start. Any help would be greatly appreciated.
      Thanks a lot
      Vasudha
        • 1. Re: photo slideshow in flash with text
          Your best bet is to search Google using "AS# slideshow tutorial", replacing the # with 2 or 3 depending on which version of actionscript you plan to use.  You are not likely to find one exactly like that one, so you should look for one that behaves similarly in some way and then figure out how to change it to be what you want.  My guess would be that most you might find that have automatic slide changes might change them horizontally, or might just fade one in atop another, so if that is all you can find, then you just need to figure out how to adapt it to work vertically instead.
