0 Replies Latest reply on Dec 14, 2009 4:24 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 12930: Optimize transformSize and transformBounds, reduce allocation of Point objects.
      Revision: 12930
      Revision: 12930
      Author:   egeorgie@adobe.com
      Date:     2009-12-14 16:23:58 -0800 (Mon, 14 Dec 2009)
      Log Message:
      This change addresses a couple of FIXMEs I had put in the internal MatrixUtil class. The parameters were changed to numbers instead of points and I unrolled the matrix multiplication to significantly reduce the number of multiplications and additions. Both methods now return reference to the same internal static Point object to further reduce dynamic object allocation.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Deepa
      Tests run: checkintests, mustella tests/gumbo/layout
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/layouts/WheelLayout.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/LayoutElementUIComponentUtils.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ScrollerLayo ut.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/core/SpriteVisualElement.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/GraphicEleme nt.as
