0 Replies Latest reply on Dec 14, 2009 7:40 PM by jmurphy67
    [svn:fx-trunk] 12936: -make sure the bundles directory for airspark is not included in the package fixes bug SDK-24552
    jmurphy67 Level 1
      Revision: 12936
      Revision: 12936
      Author:   jimurphy@adobe.com
      Date:     2009-12-14 19:40:23 -0800 (Mon, 14 Dec 2009)
      Log Message:
      -remove (from svn) the en_US/docs directories for textLayout because these directories and dita files are created by asdoc in the doc target
      -updated the main build.xml to not include the playerglobal project
      -updated fat-swc targets in osmf,automation_spark,automation_flashflexkit,automation,airspark, and textlayout to remove the doc directory.
      QE notes: make sure copylocales works properly
      Doc notes: no
      Bugs: SDK-24552
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24552
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/projects/airspark/build.xml
          flex/sdk/trunk/frameworks/projects/automation/build.xml
          flex/sdk/trunk/frameworks/projects/automation_flashflexkit/build.xml
          flex/sdk/trunk/frameworks/projects/automation_spark/build.xml
          flex/sdk/trunk/frameworks/projects/osmf/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/airframework/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/automation/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/automation_flashflexkit/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/automation_spark/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/framework/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/rpc/bundles/en_US/docs/
          flex/sdk/trunk/frameworks/projects/textLayout/bundles/en_US/docs/
