Hi
I have a form where there are a Radio Button group with 2 buttons. After checking the one or the other button, i cant reset the buttons, so that neither button one or button two are selected. The user has checked one of the buttons, and decide that neither button one nor button two should be checked, how dos the user clear the checkmarks?
Im a novice in using Live Cycle, and the English language to. :-)
Hope some one dos have a solution for this issue.
Solved! Go to Solution.
Views
Total Likes
3 buttons: YES - NO - CLEAR.
Script is on the CLEAR button.
In design mode, click on the CLEAR button and in the scripting
window enter: xfa.host.resetData("RadioButtonGroup Name");.
Use Java Script and select "click" from Event drop down
Views
Total Likes
see thread: http://forums.adobe.com/message/2262063#2262063
Views
Total Likes
Hi
I'm a totaly newbe to LiveCycle, so I don't know how to use, nor where to set in "xfa.host.resetData("form1.subform1.favouriteFoodGroup");"?
I understand that it's a sort of code, taht must be set in somewhere, please explane a bit more detailed. And how dos the user activate the funktion?
Views
Total Likes
Views
Total Likes
Hi
I had hoped there was a possibility to do it only with the 2 buttons. Fore examble if therer was cklicked on a button, that allready is marked with a cross, then the cross should be removed. Is this a possibillity or not?
I could imagine a solution code, something like "on click if 'checked' uncheck" :-)
Views
Total Likes
Hi
I have chosen to make a reset button not included in the "Yes - No" group, and used the script you advised me to, and it works fin. The reset button is set to 'invisible', so that the button only is visible in the form, when the 'Highlite Fields' option is chosen, and not in the printed version af the form.
Thanks for your help.
Views
Total Likes
Hi
Sorry! I was too guick to give a possitiv respons on the answerd. I now have found out that every click on a random reset button, resets all my radiobutton groups. Have do i solve this new issue?
I think i have made all correct, but i'm not shure.
Kind Regards Per Krog
Views
Total Likes
Add a little to the script:
xfa.host.resetData("form1.Subform1.RadioButtonListName");
Views
Total Likes
Hi
Sorry, I don't quite understand what you mean?
I think "form1" should be the filename of the form? But what is the "Subform1" part of the title?
Or is is usefull just to name the script exsakte as you have written it?
Should everey single script have a different name/tittle?
Thank you for your patience. ;-)
Kindly Per Krog
Views
Total Likes
With your form open, look in the hierarchy.
Top item: Form1
Now identify the subform that contains your radio button list
Designer defaults to: (untitled Subform) (page1) -In my example I re-named it Subform1
Now identify the name of your radio button list
Plug those into the script
Views
Total Likes
Hi
At the top of the hierarchy there is an ikon named TopmostSubform, is this what i have to use insted of (untitled Subform) in your examble?
I have a Radio Button Group named >GasMangSikJaNej<, I assume the syntax must be like this:
>xfa.host.resetData("topmostSubform.Page1.GasMangSikJaNej");<
Is this correct?
Per Krog
PS. I'm using LiveCycle Designer version 8.0.1291.1.339988, just for info.
Hi
Now i think I've got the understanding of, how it has to work.
I have a Radio Button Group named >GasMangSikJaNej<, and a resetbutton named >GasMangelReset<.
Then in the Javascript I has enteret the following script:
>xfa.host.resetData("topmostSubform.Page1.GasMangSikJaNej");xfa.host.resetData("topmostSubform.Page1.GasMangelReset")<
The first part >xfa.host.resetData("topmostSubform.Page1.GasMangSikJaNej");<, resets the button group >GasMangSikJaNej<,
and the last part >xfa.host.resetData("topmostSubform.Page1.GasMangelReset")<, resets the reset button.
If the last part is omitted, there will be set a cross/square in the ResetButton, I think it's because the reset button isn't included in the buttonGroup. I find this solution nice, because the reset button isn't visible, without if the "high light fields" setting is on. The reset button is set to Presence: Visible (Screen Only).
Thank you for all your patience and helpfull input on this issue.
Message was edited by: PerHKrog
Views
Total Likes
Glad it worked for you. Builds your confidence with the software when you can get it to work.
Views
Total Likes
I realize this is an old post, but for future readers....
An easier way to do this is to create two checkboxes, and set them to "Circle" type.
In the "Click" event for CheckBox1, add this script:
if (this.rawValue == 1) {
CheckBox2 = 0
In the "Click" event for CheckBox2, add this script:
CheckBox1 = 0
While they will not appear as a single object in the Heirarchy (as a radio button group normally would), this setup will allow you to have them as mutually exclusive, and at the same time allow you to de-select an active button so you can have both clear.
Hope this helps someone!
Views
Total Likes
