5 Replies Latest reply on Dec 16, 2009 11:04 AM by Mark in Cali
    code lookup issue Flash Builder 4 B2
    Mark in Cali Level 1
      Had this issue before with flash builder 4 beta 2 where the code look up will not work
      While working thru Day 4 EX 4.1
      "Using code lookup to generate the click event will present you with the Generate Click Handler option in the code lookup window (see Figure 4). Click the option or press the Enter key to use the option to generate a function."
      Have no problem seeing the code look up for the <s:Button> however once I get the click will not show code look up for Generate Click Handler window.. is there a way to get this to run.. to move foreward with the exercise I just wrote out the code..is there a way to trigger the code look up?
