0 Replies Latest reply: Dec 15, 2009 11:00 AM by Darrell Loverin RSS
    [svn:fx-trunk] 12966: Fix sub-applications loading RSLs into the wrong application domain.
    Darrell Loverin Adobe Employee
      Revision: 12966
      Revision: 12966
      Author:   dloverin@adobe.com
      Date:     2009-12-15 10:59:54 -0800 (Tue, 15 Dec 2009)
      Log Message:
      projects/framework/src/mx/controls/SWFLoader.as
      Fix loading sub-applications as well. Load sub-applications into a child application domain of their parent.
      projects/framework/src/mx/core/CrossDomainRSLItem.as
      projects/framework/src/mx/core/FlexModuleFactory.as
      projects/framework/src/mx/core/RSLItem.as
      projects/framework/src/mx/managers/SystemManager.as
          Pass a module factory from SystemManager and FlexModuleFactory to CrossDomainRSLItem/RSLItem. Use the moduleFactory to find the application domain of the app/modules loading the RSLs. Use this application domain to load RSLs into.
      projects/framework/src/mx/modules/ModuleLoader.as
          ?\226?\128?\156currentDomain?\226?\128?\157 is never null so remove null check.
      projects/airframework/src/mx/managers/WindowedSystemManager.as
          Added a info().currentDomain object to WindowedSystemManager.
      QE notes: None.
      Doc notes: None.
      Bugs: SDK-24698
      Reviewer: Alex
      Tests run: checkintests, MarshallPlan, Modules
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24698
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/WindowedSystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/CrossDomainRSLItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/RSLItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/modules/ModuleLoader.as
