3 Replies Latest reply on Dec 17, 2009 2:14 PM by formatlos
    Video - show first frame without autoStart
    formatlos
      hey guys,
      how can I show the first frame of a video, if autoStart is disabled?
      thanks
        • 1. Re: Video - show first frame without autoStart
          rfrishbe Level 3
          There's no easy way to do this, but essentially what you want to do is 3 methods: play(), pause(), seek(0).
          The exact pattern should be something like:
          step 0:
          set the source
          set autoPlay = false
          // add listener for step1
          step 1 (in mediaPlayerStateChangeHandler in the READY state):
          videoPlayer.muted = true;
          videoPlayer.view.visible = false;
          // call play(), here, then wait to call pause() and seek(0) in the
          // dimensionChangeHandler
          // add listener for step 2
          videoPlayer.play();
          step 2 (in dimensionChangeHandler):
          // the seek(0) is asynchronous so let's add an event listener to see when it's finsished:
          videoPlayer.addEventListener(SeekEvent.SEEK_END, videoPlayer_seekEndHandler);
          // called play(), now call pause() and seek(0);
          videoPlayer.pause();
          // add listener for step 3
          videoPlayer.seek(0);
          step 3 (in seekEndHandler):
          videoPlayer.muted = beforeLoadMuted;
          videoPlayer.view.visible = true;
          Hope that helps,
          Ryan
          • 2. Re: Video - show first frame without autoStart
            formatlos Level 1
            thanks for your reply ... that's more or less the way I've been trying to implement it.
            are there any plans for a more straightforward implementation in the framework? I would guess that this is a very common feature
            cheers Martin
            • 3. Re: Video - show first frame without autoStart
              rfrishbe Level 3
              I don't work on the OSMF team, so I can't answer for them, but this approach to load up the first frame is not really recommended practice, so I wouldn't hold my breath waiting for them to implement this feature for you.  That's because it downloads all this content automatically and makes tracking video views much harder.
              A better approach to do this would be to load up a thumbnail or an Image at first.  This will give the video its size and also display the frame you want before the user actually starts playing the video.
              -Ryan
