0 Replies Latest reply on Dec 15, 2009 1:58 PM by jmurphy67
    [svn:fx-trunk] 12970: Localization property file update 4.0.0.12968
    jmurphy67 Level 1
      Revision: 12970
      Revision: 12970
      Author:   jimurphy@adobe.com
      Date:     2009-12-15 13:58:31 -0800 (Tue, 15 Dec 2009)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ja_JP/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/modules.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/modules.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_da. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_de. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_es. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fi. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fr. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_it. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ja. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ko. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nb. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nl. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_pt. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ru. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_sv. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ TW.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_TW.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_da.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_de.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_es.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_fi.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_fr.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_it.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_ja.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_ko.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_nb.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_nl.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_pt.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_ru.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_sv.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_zh_CN.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_zh_TW.properties
