3 Replies Latest reply on Jul 21, 2010 12:55 AM by Alisa(Ying) Wang
    copy paste short-cut not function under Mac OS 10.5
    ilsh Level 1
      The TextInput component accepts shortcuts such as Apple-C and Apple-V under Mac OS 10.4and Windows. But in 10.5 the shortcut doesnt work.
        • 1. Re: copy paste short-cut not function under Mac OS 10.5
          Alisa(Ying) Wang
          Hi ilsh,
          I tried with  text/textinput/textArea in simple code. the shortcuts(cmd+c/v/a) work well on mac 10.5 , mac 10.6 . and i also tried some popular  air app, such as TweetDeck , Twhirl,and AOL.  no issue founded
          So i think there maybe some special/corner  thing i missed ,Could you please share us some pieces of sample code to reproduce this bug?
          <mx:TextArea
          x="63" y="146" width="274" >
          <mx:Text x="63" y="215" text="Text" width="274"/>
          <mx:TextArea x="63" y="241" width="274"/>
          Thanks.
          Alisa
          AIR Eng
          • 2. Re: copy paste short-cut not function under Mac OS 10.5
            ilsh Level 1
            The shortcuts relies on the default "Edit" menu which comes with every
            AIR app. I need to create a custom menu so I remove the "Edit" menu.
            The shortcuts no long work.
            ilsh
            • 3. Re: copy paste short-cut not function under Mac OS 10.5
              Alisa(Ying) Wang Level 1
              Hi ilsh,
              Thanks for your useful info . now  i can reproduce it by removing/customizing the default mac "Edit" menu.
              1. It is not an AIR bug. finally i found it was because of different menu  mechanism on mac.
              “Copy and paste functionality is commonly triggered through menu commands and keyboard shortcuts. On OS X, an edit menu with the copy and paste commands is automatically created by the operating system, but you must add listeners to these menu commands to hook up your own copy and paste functions”
              2. For more details , please refer to the help doc:
                  http://help.adobe.com/en_US/AIR/1.5/devappsflex/WS5b3ccc516d4fbf351e63e3d118666ade46-7d5a. html
              3. How to make the shortcut still work on mac after  removing/customizing the default mac "Edit" menu:
                 after your customize your default "Edit" menu, add menu commands by yourself as follows on mac:
              private
              function init():void
              stage.addEventListener(KeyboardEvent.KEY_DOWN, keyListener);
              private function keyListener(event:KeyboardEvent):void
              if (event.commandKey)
              event.preventDefault();
              switch (String.fromCharCode(event.charCode))
              case "c":
              NativeApplication.nativeApplication.copy();
              break;
              case "x":
              NativeApplication.nativeApplication.cut();
              break;
              case "v":
              NativeApplication.nativeApplication.paste();
              break;
              case "a":
              NativeApplication.nativeApplication.selectAll();
              break;
              I tested it , works well. please try again.
              Alisa
              AIR Eng
