3 Replies Latest reply on Dec 19, 2009 3:53 PM by nimmagadda_k
    Need help in sending XML via httpservice
    nimmagadda_k
         I have a requirement where I need to send an xml input to RESTful webservice developed in java.Please find the code given below that I am using to do this.Not able to do PUT or POST operation which updates a record in the backend.Please let me know whats wrong in my code given below
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
          width="530" height="610">
        <mx:script>
        <![CDATA[
          import import mx.rpc.http.HTTPService;
          public function sendXML():void
            var myXML:XML = <ns:account xmlns:ns="http://....."/>   //some valid namespace
                           <ns:name>test</ns:name>
                           <ns:phone>123456789</ns:phone>
                           </ns:account>;
           var httpService:HTTPService = new HTTPService();     httpService = new HTTPService();
           httpService.url = "http://localhost/restfulservice";
           httpService.useProxy = false;
           httpService.method = "PUT";   //also tried POST
           httpService.send(myXML);
        </mx:script>
        <!-- calling sendXML by clicking on the button below -->
        <mx:Button click="sendXML()"/>
      </mx:Application>
        • 1. Re: Need help in sending XML via httpservice
          LaVengeance
          I'm not sure if this was intentional, but in the code you've given, the XML needs to be assigned as a string. It lacks the wrapping quotes. Again, I'm not sure if you've done this just to illustrate a point.
          And I suggest you use the proxy, If you're not using the proxy, HTTPService uses a flash.net.URLLoader to make the request directly so you're limited to what the player supports.
          Also you have 2 'import' keywords in : import import mx.rpc.http.HTTPService;
          And you need not instantiate the httpservice object twice. Below is the code that I think would work :
            <mx:Script>
            <![CDATA[
                var myXML:XML = "<ns:account xmlns:ns=\"http://.....\"> <ns:name>test</ns:name> " +
                        "<ns:phone>123456789</ns:phone></ns:account>";
               httpService.useProxy = true;
            </mx:Script>
          </mx:Application>
          • 2. Re: Need help in sending XML via httpservice
            saisri2k2 Level 4
            In the last line you can do
            var obj:Object = new Object();
            obj["data"]= myXML.toXMLString();
            httpService.send( obj );
            On the server side get the data from the object and convert the string to XML
            • 3. Re: Need help in sending XML via httpservice
              nimmagadda_k Level 1
              Thanks for your replies.As you suggested I used blazeDS proxy and able to send the XML to the restful webservice which I have done this way
              service =
              new HTTPService();
              service.destination =
              "carrierAccountsService";
              service.useProxy =
              true;
              service.method =
              "PUT";
              service.contentType =
              "application/xml";
              service.addEventListener(
              "result", newAccountResult);
              "fault", httpFault);
              var xml:XML = getXMLForNewAccount();
              Alert.show(xml);
              service.send(xml);
              and configured the destintation "carrierAccountsService" in proxy-config file.But I have one more problem
              Tried to do the DELETE operation same way which accepts three parameters(id,name and comment) as given below
              var
              params:Object = {};
              params[
              "id"]= del_id.text;
              params[
              "user"]= "someuser";
              params[
              "comment"]= del_stopComments.text;
              service =
              new HTTPService();
              service.useProxy =
              true;
              service.method =
              "DELETE";
              //Alert.show("params passed are:"+ del_id.text +":"+"currentUser:"+ del_stopComments.text);
              "result", deleteAccountResult);
              Alert.show(params.id);   //printing the ID before sending request
              service.send(params);
              But when I checked the logs on the server side DELETE request is invoked but the parameters are being passed as NULL.Can some one help me on this?
              I am getting bad request error
