6 Replies Latest reply on Dec 16, 2009 7:47 AM by kglad
    Enter Text field and line breaks?
    luciewong Level 1
      I have a input textfield 200x150 where customers can write their address.
      Problem:
      Address is written like:
      Avenida de presidente
      Calle no 2
      The text arrives in my database as:
      Avenida de presidenteCalle no 2
      How can the line break be recognized in the Text field, so the text arrives in the format as written?
      The text field also has a >restrict<, it does not allow " , " ;
      Thank you for your help.
      Lucie
        • 1. Re: Enter Text field and line breaks?
          the carriage return character is "\r".  if that's not being received in your server-side script, you can substitute (use split().join() ) another character in flash and replace that character in your server-side script.
          • 2. Re: Enter Text field and line breaks?
            luciewong Level 1
            Hi kglad,
            has been a long time talking to you, how are you?
            wow, sounds good your suggestion, but....how I write this?
            I have no idea where to start.
            Lucie
            • 3. Re: Enter Text field and line breaks?
              hi lw,
              in flash, you can use:
              yourtextstring = yourtextfield.text.split("\r").join(",,");
              then in your server-side script you can convert all double commas into carriage returns.  the code you would use for that depends on your scripting language.
              • 4. Re: Enter Text field and line breaks?
                luciewong Level 1
                Kglad,
                I have a sign-up Form with several input Text fields.
                One of the TFs is >address< which is multiline/wordWrap.
                All Form content goes in 1 array.
                So each Text field represents 1 array element.
                So I have a TF Listener>
                Listener.onChanged = function(txt){
                thetext = txt.text.split(“\r”).join(“..”);
                content_array.splice(theno,1,thetext);
                Works great, whenever I have a break in address for ex. It will put me a “..” into the string.
                My content_array looks then like:
                [aaaa,bbbb,cc..ccc..cccc..cc,ddd,eee] where the “ccc” element is the address field.
                I probably could now manage in my ASP to replace the “..” with ??? what?? Don’t know yet, so the Database could read a line break.
                But…..huah,
                I would guess, that my string for the address field in the Database would look for the moment like> cc..ccc..cccc..cc <.
                But does not, it looks like > ccccccccccc < . So already now also the “..” are taken away.
                That’s bad, isn’t it?
                • 5. Re: Enter Text field and line breaks?
                  luciewong Level 1
                  To those interested,
                  what I did now in my ASP.
                  theContent = replace(Request("value" & i),chr(13),"<br>")
                  my address string looks now in the DB like >> cc<br>ccc<br>cccc<br>cc <. which is much better than before.
                  On return I will then replace the >br< with “\n”.
                  Thankyou kglad.
                  • 6. Re: Enter Text field and line breaks?
                    you're welcome.
                    if you still can, mark this thread as answered.
