3 Replies Latest reply on Dec 16, 2009 6:54 AM by Gregory Lafrance
    Autosize the container when changing states
    Shivik
      Hello all
      I have created a hierarchy of views like this....
      MainPage.mxml
      Sidebar.mxml
      UserPanel.mxml
      LoginPanel.mxml
      MemberMenu.mxml
      SearchPanel.mxml
      NavigationLinksPanel.mxml
      MainContents.mxml
      Now I want that when I display an error state in LoginPanel.mxml, the views should be autosized to fit the content. I don't want the scrollbar to appear. Setting the scrollPolicy to off just cuts the content - it doesn't autosize.
      Can this be done? Any suggestions anyone?
      With best regards
      ShiVik
        • 1. Re: Autosize the container when changing states
          Gregory Lafrance Level 6
          Which container is having its content cutoff?
          You have to be careful to set containers to width="100%" (percentWidth=100 in AS) when necessary.
          This may not always be possible, because you may have a container that you do not want to expand as much as may be possible with width set to 100%.
          But most times when I'm getting unwanted scrollbars I need to set one of the parent containers' width to 100%. The challenge is to figure out which one.
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance
          www.ChikaraDev.com
          Flex Development and Support Services
          • 2. Re: Autosize the container when changing states
            Shivik Level 1
            Hello there Greg
            The container that has its content cut-off is mx:Box. I have based all my components as mx:Box. So I guess I will have to set the width and height to 100% for every container that houses the component. This does work with height also, right?
            Thanks and Regards
            ShiVik
            • 3. Re: Autosize the container when changing states
              Yes, it also works for height.
              Usually setting width and height to 100% is the way to go, because the containers simply resize to their content, and the UI displays as you have planned. In some case-by-case circumstances you might need to tweak things, such as using Canvas, fixed sizes, etc.
              Greg Lafrance
              www.ChikaraDev.com
