0 Replies Latest reply on Dec 16, 2009 6:44 AM by Paul Reilly
    [svn:fx-trunk] 12994: * Fixes for two issues that were showing up in FB.
    Paul Reilly Level 1
      Revision: 12994
      Revision: 12994
      Author:   preilly@adobe.com
      Date:     2009-12-16 06:44:45 -0800 (Wed, 16 Dec 2009)
      Log Message:
      • Fixes for two issues that were showing up in FB.
      QE notes:
      Doc notes:
      Bugs: SDK-24669, SDK-24686
      Reviewer: Corey
      Cycloner: George
      Tests run: checkintests
      Is noteworthy for integration: yes, fixes two FB issues.
      Code-level description of changes:
        modules/compiler/src/java/flex2/tools/PreLink.java
          Modified postRun() to swap in the root CompilationUnit's Logger
          when validating it's StyleContainer.  This allows the warnings
          from StylesContainer.validate() to be persisted across incremental
          compilations.  This fixes SDK-24686.
        modules/compiler/src/java/flex2/compiler/Source.java
          Made getLogger() public, so it could be called from PreLink.
        modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          Modified compile() to check forcedToStop() after each PreLink
          batch.  This fixes SDK-24669.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24669
          http://bugs.adobe.com/jira/browse/SDK-24686
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/linker/CULinkable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
