4 Replies Latest reply on Dec 16, 2009 2:16 PM by bryancolley
    Error: Can't get every item of...
    bryancolley
      I have a script that worked find in Tiger but it gives me an error
      after I upgraded to Leopard 10.5.8.  I'm not sure how to fix it.
      The script is supposed to make a list of dates that I can choose from.
      Here it is:
                      repeat with curyear in myyear
                               repeat with curmonth in mymonth
                                       repeat with curdate in mydate
                                               set mytemp to curmonth & " " & curdate & ", " & curyear
                                               set myjournal to (every item of myjournal) & mytemp
                                       end repeat
                               end repeat
                       end repeat
      But now I get an error saying:
      "Can’t get every item of \"\"."
      Help please!
        • 1. Re: Error: Can't get every item of...
          sstanleyau Level 4
          You're not showing the full script, so it's impossible to tell. Where is the error happening? Where does myjournal come from?
          • 2. Re: Error: Can't get every item of...
            bryancolley Level 1
            Sorry about that. Here's the complete script. It should come up with a list
            of dates to choose from.
            tell application "Adobe InDesign CS2"
                    activate
                    set mydoc to active document
                    set myjournal to ""
                    set myyear to {2009, 2010}
                    set mymonth to {"January", "February", "March", "April", "May",
            "June", "July", "August", "September", "October", "November", "December"}
                    set mydate to {1, 15}
                            end repeat
                        end repeat
                    end repeat
                    set mypick to (choose from list myjournal) as string
                    display dialog mypick
            end tell
            Bryan Colley
            jupiterkansas@gmail.com
            • 3. Re: Error: Can't get every item of...
              sstanleyau Level 4
              You still haven't said where you're getting the error -- it works here.
              Try changing:
                      set myjournal to ""
              to
                      set myjournal to {}
              and:
              to
                               set end of myjournal to  mytemp
              • 4. Re: Error: Can't get every item of...
                bryancolley Level 1
                The error came with the
                line, but your suggestions totally fixed everything. I can't thank you
                enough!
                Bryan Colley
