3 Replies Latest reply on Dec 18, 2009 8:33 AM by zzzjie
    mxmlc compiler parameter?
    zzzjie
      Hi:
      I am trying to upload a .properties file to a web server (linux), let server compile it into .swf file, then the user can download it.
      However, the compile failed:
      /tmp/Adobe/Flex/GeneratedResourceModules/GeneratedResourceModule40155.as(13): col: 51 Error: The definition of base class ModuleBase was not f
      ound.
      public class GeneratedResourceModule40155 extends ModuleBase
      /tmp/Adobe/Flex/GeneratedResourceModules/GeneratedResourceModule40155.as(14): col: 16 Error: Interface IResourceModule was not found.
          implements IResourceModule
      Seems like the mxmlc create some temp file and directory in the /tmp and the wwwrun can not do it.
      Is it possible to configure this default location /tmp to somewhere else?
        • 1. Re: mxmlc compiler parameter?
          Flex harUI Adobe Employee
          The console should list which flex-config.xml it is using.  Make sure the SWCs are in the lib-path used by that flex-config.xml
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: mxmlc compiler parameter?
            zzzjie Level 1
            I am sorry but can you give me some details?
            I am new to this FLEX. This is my problem:
            I built a FLex application that can upload a .properties file to a Linux web server. The file uploaded is in my home directory. I also installed the Flex SDK  under my home directory.
            The script (upload.php) ran the "mxmlc" command from shell_exec(). But the command failed, since it can not create any file under /tmp/Adobe/Flex/GeneratedResourceModules/, where the compiler puts the temporary files.
            Would it be possible that I can instruct the mxmlc to put the temporary file under my home directory? Thanks
            • 3. Re: mxmlc compiler parameter?
              zzzjie Level 1
              temporary files.
