3 Replies Latest reply on Jan 29, 2010 8:48 AM by Otuyelu
    Am I the only one who has a problem trying to complete the O'Reilly Gettining Started with Flex3 PDF
    deewayne22
      This is the first time i am trying to understand any and everyhign flex.  So i am trying to go through the pdf which is recommended to get acquainted with the program. One issue i see is that the pdf leaves out details right from the star.  The next issue is that when i try to run the initial example program, the compiler has an issue with a negative number given to the rotation (mind you, this number is what's in the example) and then the last issue is that the image that you are supposed to use sems to have two different filenames in the tutorial. At this point i just gave up and am wondering if it's me or the tutorial.  I'm pretty sure its the pdf. But is it me? Let me know
