0 Replies Latest reply on Dec 16, 2009 1:54 PM by Paul Reilly
    [svn:fx-trunk] 13007: * Fixed some deprecation warning configuration issues and cleaned up
    Paul Reilly
      Revision: 13007
      Revision: 13007
      Author:   preilly@adobe.com
      Date:     2009-12-16 13:54:31 -0800 (Wed, 16 Dec 2009)
      Log Message:
      • Fixed some deprecation warning configuration issues and cleaned up
        the DMV deprecation warnings in our build.
      QE notes:
      Doc notes:
      Bugs: SDK-24749, SDK-24738
      Reviewer: Corey
      Tests run: checkintests
      Is noteworthy for integration: yes, fixes DMV deprecation warnings
      Code-level description of changes:
        frameworks/projects/automation_dmv/build.xml
        frameworks/projects/datavisualization/build.xml
          Turned off deprecation warnings for DMV SWC's.
        modules/antTasks/src/flex/ant/MxmlcTask.java
        modules/antTasks/src/flex/ant/CompcTask.java
        modules/compiler/src/java/flex2/configuration_en.properties
        modules/compiler/src/java/flex2/compiler/common/Configuration.java
        modules/compiler/src/java/flex2/compiler/config/ConfigurationException_en.properties
        modules/compiler/src/java/flex2/compiler/config/ConfigurationException.java
          Renamed user-locale to tools-locale.
      modules/compiler/src/java/flex2/compiler/css/StyleDef.java
         Modified processReference() to use MxmlDocument.isDeclared() to
         check if a PropertyReference exists on the document.  This fixes
         SDK-24738.
      modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      modules/compiler/src/java/flex2/compiler/i18n/I18nCompiler.java
      modules/compiler/src/java/flex2/compiler/as3/As3Configuration.java
         Added showDeprecationWarnings().
      modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
         Modified processCoachSettings() to turn off all deprecation
         warnings when showDeprecationWarnings() is false.
        modules/compiler/src/java/flash/css/StyleParser.java
          Modified warnDeprecation() to respect "checkDeprecation" variable.
        modules/compiler/src/java/flex2/compiler/media/SVGTranscoder.java
          Modified doTranscode to respect showDeprecationWarnings.
        modules/compiler/src/java/flex2/tools/WebTierAPI.java
          Modified getTranscoders() to pass showDeprecationWarnings into the
          SVGTranscoder constructor.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24749
          http://bugs.adobe.com/jira/browse/SDK-24738
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/automation_dmv/build.xml
          flex/sdk/trunk/frameworks/projects/datavisualization/build.xml
          flex/sdk/trunk/modules/antTasks/src/flex/ant/CompcTask.java
          flex/sdk/trunk/modules/antTasks/src/flex/ant/MxmlcTask.java
          flex/sdk/trunk/modules/compiler/src/java/flash/css/StyleParser.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException.jav a
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_en. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/I18nCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/SVGTranscoder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
