2 Replies Latest reply on Dec 17, 2009 12:44 PM by carlopip
    Problem with AR9 and IE
    carlopip
      When I try to access a pdf document from inside IE v.8 I get an error message: the browser blocks and the document can't be opened.
      Reading pdf files stored in my hard disk does not give any problem.
      Win 7 Pro 64bit
      IE v.8
      AR v.9
        • 1. Re: Problem with AR9 and IE
          HeatherEHowe
          We have the same problem as well with XP ... however is it just larger documents ... more then 3 pages... We haven't found a solution to this problem either other then telling people to right click and save the pdf and open it that way..
          • 2. Re: Problem with AR9 and IE
            carlopip Level 1
            In another laptop with Vista and IE8 I had the same problem. I was advised in this forum to select a certain option in the AR9 preferencres... but I don't remember which one... and it worked!
            Now I can't open any pdf from the IE, and often also normal pdf files stored in my hd cannot be opened.
