0 Replies Latest reply on Dec 16, 2009 2:35 PM by jmurphy67
    [svn:fx-trunk] 13011: Localization property file update 4.0.0.13007
    jmurphy67 Level 1
      Revision: 13011
      Revision: 13011
      Author:   jimurphy@adobe.com
      Date:     2009-12-16 14:35:29 -0800 (Wed, 16 Dec 2009)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_da. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_de. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_es. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fi. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fr. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_it. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ja. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ko. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nb. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nl. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_pt. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ru. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_sv. properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ TW.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_TW.properties
