0 Replies Latest reply on Dec 16, 2009 5:39 PM by Peter Farland
    [svn:fx-trunk] 13023: Updating Xerces 2.9. 1 Patch source file comments to reflect history of changes from Xerces 2.4. 0 to Xerces 2.9.1 after review by jruehr.
    Peter Farland Level 3
      Revision: 13023
      Revision: 13023
      Author:   pfarland@adobe.com
      Date:     2009-12-16 17:39:36 -0800 (Wed, 16 Dec 2009)
      Log Message:
      Updating Xerces 2.9.1 Patch source file comments to reflect history of changes from Xerces 2.4.0 to Xerces 2.9.1 after review by jruehr.
      Updated the build manifest to reflect that this is a patch against Xerces 2.9.1.
      Rebuilt the /lib/xercesPatch.jar using JDK 1.4.2_12 to get the updated manifest information.
      Updated /lib/xerces-LICENSE.txt to reflect Xerces 2.9.1 license which is now under the Apache License 2.0.
      Added /lib/xerces-NOTICE.txt that ships with Xerces 2.9.1.
      Updated top level build.xml packaging to pick up this new NOTICE file.
      Corrected the comment on XMLAttributesMMImpl.java to match parent XMLAttributesImpl.java from Xerces 2.9.1.
      QE notes: N/A
      Doc notes: N/A
      Bugs: SDK-24204 - Some surrogate characters get duplicated in component labels
      Reviewer: jruehr, Frances
      Tests run: Checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24204
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/lib/xerces-LICENSE.txt
          flex/sdk/trunk/lib/xercesPatch.jar
          flex/sdk/trunk/modules/thirdparty/xerces-patch/build.xml
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/impl/XMLDocumen tFragmentScannerMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/impl/XMLDocumen tScannerMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/impl/XMLNSDocum entScannerMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/jaxp/SAXParserF actoryMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/jaxp/SAXParserM MImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/Abstrac tSAXParserMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/Integra tedParserConfigurationMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/SAXPars erMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/parsers/XML11Co nfigurationMMImpl.java
          flex/sdk/trunk/modules/thirdparty/xerces-patch/src/java/org/apache/xerces/util/XMLAttribu tesMMImpl.java
      Added Paths:
          flex/sdk/trunk/lib/xerces-NOTICE.txt
