0 Replies Latest reply on Dec 16, 2009 5:51 PM by Jason Szeto
    [svn:fx-trunk] 13026: UITextField and UIFTETextField measurement fixes
    Jason Szeto Level 3
      Revision: 13026
      Revision: 13026
      Author:   jszeto@adobe.com
      Date:     2009-12-16 17:51:29 -0800 (Wed, 16 Dec 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-24687 - DateField does not position month/year as expected in date dropDown
      when scale is applied
      UITextField and UIFTETextField were returning incorrect values for measuredHeight and measuredWidth when an ancestor was scaled.
      UITextField works around a quirk of a scaled TextField. When using device fonts, textWidth and textHeight return a value modified by scale (when it really shouldn't).
      I?\226?\128?\153ll use the term "scaledWidth" and "scaledHeight" to represent the actual pixel dimensions of a scaled textField. This is the dimensions of the textField as it appears on the screen.
      textWidth = scaledWidth / scaleX
      textHeight = scaledHeight / scaleX
      To calculate the unscaled textWidth and textHeight, we need to multiply textWidth and textHeight by scaleX / scaleY.
      unscaled textWidth = textWidth * scaleX / scaleY
      unscaled textHeight = textHeight * scaleX / scaleY
      UIFTETextField properly returns textWidth and textHeight properties even when scaled. So measuredWidth and measuredHeight can just use textWidth and textHeight when using device or embedded fonts.
      DateChooser was measuring and laying itself out before it was added to the stage (which is true for all components in an application). Thus it was not getting the correct measurements for the month and year textFields. The fix is to listen for the addedToStage event and invalidate our size if scaleX or scaleY != 1.
      QE notes: Add tests for scaled DateChooser and DateField
      Doc notes: None
      Bugs: SDK-24687
      Reviewer: Alex
      Tests run: checkintests, DateChooser, DateField
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/UIFTETextField.as
