2 Replies Latest reply on Dec 17, 2009 3:14 PM by Mark in Cali
    Exercise 4.5: Making an HTTP request with parameters
    Mark in Cali Level 1
      Is there a bug in the HTTP request : <s:request>. ? I've worked and reworked ex 4.5, 4 times then tried the solution code and the request to the xml will not filter by location.
      I'm using a local xml file so the only change I made to the file was pointing to the xml file on my pc, in the exercise I coded
      I always get back the full xml file.
      I tried doing a final build on the solution to test it on a pc with a net connection but get an http security error. and when the only change I made in the solution code is to to point to a local xml file - it works but again will not filter on location
      Is this a beta bug or an issue on my pcs?
      Thanks!
