14 Replies Latest reply on Oct 11, 2006 1:21 PM by T._Ruggles
    Parsing data from java though RemoteObject
    ciwee_ufrj Level 1
      HI all
      Due this forum I finnally got make my Flex application talk to a Java method at the server through FDS/RemoteObject
      Although I searched and didnt find how to parse data retrieved from java to AS3.. I'm trying to show them in DataGrid but its being hard.
      Flex is really lacking good materials on the web :(
      Some one can indicate a good online tutoriol about this???
      THX!!!
        • 1. Re: Parsing data from java though RemoteObject
          T._Ruggles
          How are you trying to use the data on the client? Would you show some more code?
          Thanks.
          • 2. Re: Parsing data from java though RemoteObject
            ciwee_ufrj Level 1
            I want exemples about data treating, I don't have any code because I dont know what to do.
            Do you have an example.. or tutorial.. or something like that?
            thank you..
            • 3. Parsing data from java though RemoteObject
              T._Ruggles Level 1
              The best example I could find is in the language ref - http://livedocs.macromedia.com/flex/2/langref/mx/rpc/remoting/mxml/RemoteObject.html. It shows making the call as well as binding to its result. The key is to get familiar with the structure of the object that is returned. For this you could use describeType()( http://livedocs.macromedia.com/flex/2/langref/flash/utils/package-detail.html).
              You can also try mx.utils.ObjectUtil.toString(ro.yourMethod.lastResult) to see what the result format looks like.
              • 4. Re: Parsing data from java though RemoteObject
                ciwee_ufrj Level 1
                quote:
                <mx:RemoteObject id="RO" destination="MyRemoteObjectDest"
                fault="Alert.show(event.fault.faultstring), 'Error'">
                <mx:method name="GetQuote">
                <mx:arguments>
                <symbol>{stockSymbol.text}</symbol>
                </mx:arguments>
                </mx:method>
                </mx:RemoteObject>
                <mx:Panel title="RemoteObject Example" height="75%" width="75%"
                paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10">
                <mx:Label width="100%" color="blue"
                text="Enter a stock symbol to obtain a quote."/>
                <mx:TextInput id="stockSymbol" text="ADBE"/>
                <mx:Button label="Get Quote" click="RO.GetQuote.send()"/>
                <mx:Text htmlText="Company: {RO.GetQuote.lastResult.GetQuoteResult.StockQuote.Company}"/>
                <mx:Text htmlText="Current price: ${RO.GetQuote.lastResult.GetQuoteResult.StockQuote.Price}"/>
                </mx:Panel>
                Thanks, but look at this code, in order to this structure -> "RO.GetQuote.lastResult.GetQuoteResult.StockQuote.Price" work, the result must be XML doesnt it? I am a little bit confused on the understandind of the resulted object :(
                Cheers
                • 5. Re: Parsing data from java though RemoteObject
                  T._Ruggles Level 1
                  RemoteObject calls translate Java Arrays to AS ArrayCollections of objects. Based on your orignal DBAdmin / Traducao post the code could look something like this.
                  <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" >
                  <mx:Script>
                  <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.controls.Alert;
                  import mx.rpc.events.ResultEvent;
                  import mx.rpc.events.FaultEvent;
                  import mx.utils.ObjectUtil;
                  [Bindable]
                  public var lista:ArrayCollection;
                  [Bindable]
                  public var currentRecord:*;
                  private function processaDados(event:ResultEvent):void{
                  lista = event.result as ArrayCollection;
                  private function processaDadosFault(event:FaultEvent):void{
                  Alert.show(ObjectUtil.toString(event.fault));
                  </mx:Script>
                  <mx:RemoteObject id="ro" destination="DataAccess">
                  <mx:method name="retornaDados" result="processaDados(event)" fault="processaDadosFault(event)"/>
                  </mx:RemoteObject>
                  <mx:Button click="ro.retornaDados()" />
                  <mx:Label id="theID" text="{currentRecord.id}" />
                  <mx:Label id="texto" text="{currentRecord.texto}" />
                  <mx:Label id="traducao" text="{currentRecord.traducao}" />
                  <mx:DataGrid id="dg" dataProvider="{lista}" change="currentRecord = dg.selectedItem"/>
                  <!-- or -->
                  <mx:DataGrid dataProvider="{ro.retornaDados.lastResult}">
                  <mx:columns>
                  <mx:DataGridColumn dataField="id" headerText="ID" />
                  <mx:DataGridColumn dataField="traducao" headerText="Traducao" />
                  <mx:DataGridColumn dataField="texto" headerText="Texto" />
                  </mx:columns>
                  </mx:DataGrid>
                  <!-- <DebugComponent xmlns="qa.utils.*" /> -->
                  </mx:Application>
                  • 6. Parsing data from java though RemoteObject
                    ciwee_ufrj Level 1
                    Good! At this time I can't test it but it really helped me to clear my ideas.
                    Reading your example, I see that when the Client-App gets the array from the server, "IT KNOWS HOW TO PULL OUT PRIMARY DATA TYPES FROM TRADUCAO", am I right? I got confused because I could not imagine how AS3 would treat the Traducao type since it was created by me! And I got even more confused reading an article at Livedocs about Class Mapping. It seemed to me that, in order to a not-standard class (like mine) be understood by AS3, it would first be mapped.
                    Thank you for your effort Ruggles
                    • 7. Re: Parsing data from java though RemoteObject
                      T._Ruggles Level 1
                      That is correct. Our serialization mechanism converts the object into its basic types. If the class is unknown to the client then a simple AS Object will be created with the data. If it is a known type (ours or yours with a mapping) then we attempt to create a client instance of the given type.
                      If you had a client-side type for Traducao you'd just add this line to the top, make sure it gets linked in by using it somewhere in your MXML and the deserialized result should use it.
                      package pdv {
                      [RemoteClass alias="pdv.Traducao"]
                      public class Traducao{
                      public var id:int;
                      public var texto:String;
                      public var traducao:String;
                      public function Traducao() {}
                      • 8. Re: Parsing data from java though RemoteObject
                        ciwee_ufrj Level 1
                        Lol... these new technologies are getting really tricky ah???
                        But my Traducao data class is based on GETTERS & SETTERS. Does it know how to pull out primary data types even though??? How will AS3 know what getter function to associate with a primary variable? Or maybe the PRIVATE attribute is not respected by AS3 and it's content can be extracted...
                        • 9. Re: Parsing data from java though RemoteObject
                          T._Ruggles Level 1
                          Yes, it considers public getters and setters first, then pubic properties. The example above worked for me when using your Traducao class (although I short-circuited the DB code and just created a bunch manually in DBAdmin.retornaDados.
                          for (int i=0; i<10; i++) {
                          list.add(new Traducao(i, "record" + i, "still" + i));
                          • 10. Re: Parsing data from java though RemoteObject
                            ciwee_ufrj Level 1
                            Good.
                            So it might have some algo to guess the getter method name based on the variable name. Most of the cases it is simple getVar but it is not a rule.
                            Thank you for your answer... I really appretiate it.
                            • 11. Re: Parsing data from java though RemoteObject
                              ciwee_ufrj Level 1
                              Ruggles.. When I tested the sample you provided me using my Traducao class (tested other examples from myself too), the application worked fine but the data wasnt retrieved from server and I got no error.. my Firefox show a message in the bottom -> "Receiving data from server localhost"
                              This message doesnt go away.. do you know what is happening? thxx!!! :)
                              • 12. Re: Parsing data from java though RemoteObject
                                T._Ruggles Level 1
                                You can get more information by turning on logging on both client and server. For the server, in server-config.xml you'd want to add something like this to the logging section (make sure level="Debug"):
                                <target class="flex.messaging.log.ConsoleTarget" level="Debug" >
                                <properties>
                                <prefix>[Flex] </prefix>
                                <includeDate>true</includeDate>
                                <includeTime>true</includeTime>
                                <includeLevel>true</includeLevel>
                                <includeCategory>false</includeCategory>
                                </properties>
                                <filters>
                                <pattern>Endpoint.*</pattern>
                                <pattern>DataService.*</pattern>
                                <pattern>Service.*</pattern>
                                <pattern>Message.command.*</pattern>
                                <pattern>Message.data.*</pattern>
                                </filters>
                                </target>
                                This will add a lot of debugging info to the server console so you can see the RO calls and responses. In the client app you can add:
                                <mx:TraceTarget level="0"/>
                                This will trace the client side of the picture to your flashlog.txt.
                                • 13. Re: Parsing data from java though RemoteObject
                                  ciwee_ufrj Level 1
                                  Thx man.. I'll try it right now.. do you think the problem can be at the java side? will log let me know that?
                                  • 14. Re: Parsing data from java though RemoteObject
                                    T._Ruggles Level 1
                                    I really don't know. But piecing together the logs should give you a clearer picture of what is happening.
