2 Replies Latest reply on Dec 17, 2009 5:58 PM by jerryhamby
    Perfect time to capture image size???
    jerryhamby Level 1
      I'm looking for the perfect event to retrieve the width and height of an image that just loaded.
      I need to resize the images before displaying.
      I'm getting different readings when I use a regular ImageElement as opposed to wrapping the same ImageElement
      inside a TemporalProxyElement.   The regular works fine and returns the currentTarget width and height,
      the TemporalProxyElement ImageElement  returns zeros for the width and height.
      Why the different???
      ===== code =======
      pImageSerialElement.addChild(new TemporalProxyElement(3, new ImageElement(new ImageLoader(), new URLResource(new URL("./images/image4.jpg")))));
      ===== traces =======
      mImageLoadableStateChange evt = [Event type="loadableStateChange" bubbles=false cancelable=false eventPhase=2]
      mImageLoadableStateChange evt.newState = loaded
      Successfully connected!
      pMediaSprite.width =  0
      pMediaSprite.height =  0
      AppMaster.getInstance().pStageWidth =  320
      AppMaster.getInstance().pStageHeight =  480
      mImageLoadableStateChange evt.currentTarget.width =  0
      mImageLoadableStateChange evt.currentTarget.height =  0
      ===== code =======
      var vImageElement = new ImageElement(new ImageLoader(), new URLResource(new URL( "./images/image4.jpg")));
      pMediaSprite.width =  300
      pMediaSprite.height =  240
      mImageLoadableStateChange evt.currentTarget.width =  600
      mImageLoadableStateChange evt.currentTarget.height =  800
        • 1. Re: Perfect time to capture image size???
          RyanOConnell Level 2
          Could you post your code or file a bug?  It looks like you first example isn't complete, you are using a serial element as well?
          Ryan
          Here is a working example:
          private static const REMOTE_IMAGE:String = "http://mediapm.edgesuite.net/osmf/image/adobe-lq.png";
          private function init():void
          mediaPlayerWrapper.mediaPlayer.addEventListener(MediaPlayerStateChangeEvent.MEDIA_PLAYER_S TATE_CHANGE, onState);
          mediaPlayerWrapper.element = new TemporalProxyElement(3, new ImageElement(new ImageLoader(), new URLResource(new URL(REMOTE_IMAGE))));
          private function onState(event:MediaPlayerStateChangeEvent):void
          if(event.state == MediaPlayerState.READY)
          trace('mediaPlayerWrapper.mediaPlayer.height' + mediaPlayerWrapper.mediaPlayer.height);
          trace('mediaPlayerWrapper.mediaPlayer.width' + mediaPlayerWrapper.mediaPlayer.width);
          </mx:Script>
          <players:MediaPlayerWrapper id="mediaPlayerWrapper" width="100%" height="100%"/>
          </mx:Application>
          • 2. Re: Perfect time to capture image size???
            jerryhamby Level 1
            Filed bug: FM-301
            I will review your code, to see if I'm missing anything.
            My issue is with the:
            LoadableStateChangeEvent.LOADABLE_STATE_CHANGE
            Your code deals with it in:
            MediaPlayerStateChangeEvent.MEDI A_PLAYER_STATE_CHANGE
            I will give it a shot, but I still think it should work on LoadableStateChangeEvent.
            ImageElement worked fine there without the TemporalProxyElement wrapper.
