0 Replies Latest reply on Dec 17, 2009 4:56 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 13090: Fix http://bugs.adobe.com/jira/browse/ SDK-24683 text labels exceeding ButtonBarButton bounds when resizing the Spark ButtonBar control
    Evtim Georgiev (Adobe) Level 2
      Revision: 13090
      Revision: 13090
      Author:   egeorgie@adobe.com
      Date:     2009-12-17 16:56:07 -0800 (Thu, 17 Dec 2009)
      Log Message:
      Fix http://bugs.adobe.com/jira/browse/SDK-24683 text labels exceeding ButtonBarButton bounds when resizing the Spark ButtonBar control
      Problem: The baselinePosition getter calls internal method validateBaselinePosition(), which in turns resizes the component to its explicit or measured actual size if width or height is zero. This is incorrectly functioning, since the size of the component is not restored afterwards.
      Fix: Do this auto-changing of the actualSize only if layout has not resized the component yet.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24683
      Reviewer: Glenn, Corey
      Tests run: checkintests, mustella tests/gumbo/components
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
