0 Replies Latest reply on Dec 17, 2009 4:59 PM by Peter Farland
    [svn:fx-trunk] 13091: Fixing alpha masks by adapting to FXGUtils changes when processing shapes that have masks and filters applied  ( to match the rendering order when the same test case in MXML-G which uses the ActionScript drawing API ).
    Peter Farland Level 3
      Revision: 13091
      Revision: 13091
      Author:   pfarland@adobe.com
      Date:     2009-12-17 16:59:38 -0800 (Thu, 17 Dec 2009)
      Log Message:
      Fixing alpha masks by adapting to FXGUtils changes when processing shapes that have masks and filters applied (to match the rendering order when the same test case in MXML-G which uses the ActionScript drawing API).
      Add java doc on methods to clarify how we process "advanced" graphics features not natively supported in SWF alone.
      QE notes: Yes, please look at alpha masks and luminosity masks on shapes, including those that also use filters.
      Doc notes: N/A
      Bugs: SDK-24733 - Alpha masks do not work when you also have a filter on the graphic
      Reviewer: For Sujata
      Tests run: Checkintests, mustella spark/core/fxg
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24733
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
