0 Replies Latest reply on Dec 17, 2009 6:59 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 13099: Minor updates to the drag and drop protected APIs.
    Evtim Georgiev (Adobe) Level 2
      Revision: 13099
      Revision: 13099
      Author:   egeorgie@adobe.com
      Date:     2009-12-17 18:58:52 -0800 (Thu, 17 Dec 2009)
      Log Message:
      - LayoutBase calculateDragScrollDelta now takes only two parameters, the timeInterval parameter was removed while the timeElapsed interval was renamed to elapsedTime and its type was changed from int to Number.
      - The drag and drop data format descriptors were renamed from "orderedItems" and "orderedItemsCaretIndex" to "itemsByIndex" and "caretIndex" respectively.
      - Fixed a default value for the VerticalLayout requestedMinRowCount property to be -1 (was 0).
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Jason
      Tests run: checkintests, mustella tests/gumbo/components/ListDragDrop
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/HorizontalLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/VerticalLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LayoutBase.as
