4 Replies Latest reply on Dec 18, 2009 7:17 AM by penyfai
    Comparison of arrays to find elements that differ - JS??
    penyfai Level 1
      I think I've got my logic all wrong.
      I'm trying to compare two arrays, with the result being that I get a new array with the elements in the first that are missing from the second.
      array1 - a,b,c,d,e
      array2 - a,b,c
      new array should contain d,e
      THIS IS WHAT I'M TRYING.........
      //--------------------------------------- Function for getting graphics ---------------------------------------
      function getGraphicsFunc()
      //--------------------------test for graphics in Library--------------------------
      var mylib = app.libraries.item(0);
      //get list of graphics in Library
      var libGraphicList = mylib.assets.everyItem().name;
      alert(libGraphicList);        <--THIS WORKS FINE
      //-------------get list of all graphics available for CID on Pulse_OPI -------------
      var graphicFolder = Folder(basegraphpath + lastdigits + "/");
      var theGraphics = graphicFolder.getFiles();
      var allGraphics = [];
      //match files to Content ID of advert
      for (i=0; i<theGraphics.length; i++)
           //Assuming is 8 numbers sequence is a static number.
           //You can also use grep to match 8 digits >
           // if(theFiles[i].name.match(/^\d{8}/);
      if(theGraphics[i].name.indexOf(adCID)==0)
                allGraphics.push(theGraphics[i].name);
      alert(allGraphics);        <--THIS WORKS FINE - the next comparison is the problem.....
      //Compare graphic arrays to see which are NOT in library
      var missingGraphics = [];
      for (j=0; j<allGraphics.length; j++)
      if(toString(libGraphicList).indexOf(allGraphics[j])==-1)
      missingGraphics.push(allGraphics[j]);
      alert(missingGraphics);        <--THIS ALWAYS PRODUCES THE SAME 'MISSING GRAPHICS'  EVEN IF THEY ARE IN THE INDL
      var graphicsFound = (missingGraphics.length)
      alert("There were " + graphicsFound + " graphics found and imported to the library")
      Many thanks in advance and Happy Christmas everyone.....
