1 Reply Latest reply on Dec 18, 2009 10:44 AM by Flex harUI
    Need help with System.setClipboard error
    jeff.johnson
      SDK version: 3.3.0.4589
      Requires flash 10.0.12 or higher
      Code:
      private function sendTextToClipboard():void
           System.setClipboard("User Name: " + uname + "\n" + "Password: " + pword);
      I am using the System.setClipboard function in my application and have incountered an interesting problem.
      When the call is made on a windows box (XP and Vista) IE crashes.
      The following is the Vista IE error that is being thrown:
      Problem signature:
      Problem Event Name: APPCRASH
      Application Name: iexplore.exe
      Application Version: 8.0.6001.18865
      Application Timestamp: 4b077416
      Fault Module Name: Flash10c.ocx
      Fault Module Version: 10.0.32.18
      Fault Module Timestamp: 4a613d79
      Exception Code: c0000005
      Exception Offset: 0016f1f2
      OS Version: 6.0.6002.2.2.0.256.6
      Locale ID: 1033
      Additional Information 1: fd00
      Additional Information 2: ea6f5fe8924aaa756324d57f87834160
      Additional Information 3: fd00
      Additional Information 4: ea6f5fe8924aaa756324d57f87834160
      The following is the XP SP3 IE error:
      Internet Explorer has encountered a problem with an add-on and needs to close.
      The following add-on was running when this problem occured:
      File:    FlDbg10b.ocx
      iexplore.exe - Application Error
      The instruction "0x052bee0e" referenced memory at "0x00000018".  The memory could not be read.
      Any help would be greatly apprieciated.
