2 Replies Latest reply on Dec 18, 2009 8:44 AM by BoydMills
    .mxml .as syntax question
    BoydMills Level 1
      login.mxml file:
      <vci:LoginBase
      xmlns:mx="http://www.adobe.com/2006/mxml"
      xmlns:vci="com.vcicontrols.gui.*"
      borderStyle="none"
      width="600" height="400" horizontalCenter="0" verticalCenter="0"
      backgroundAlpha="0.3"  backgroundSize="100%"
      initialize="init();"
      creationComplete="startup();"
      <mx:Image scaleX="0.3" scaleY="0.3" left="5" id="WelcomeVCILogo"  />
      </vci:LoginBase>
      loginbase.AS FILE:
            WelcomeVCILogo.data = VCIConfigurationData.Image;
      generates error:
      1120: Access of undefined property WelcomeVCILogo. VCI/src/com/vcicontrols/gui LoginBase.as line 150 1261149262122 3420
      The odd thing is that when I comment out the offending line and step over it with the debugger, the variable WelcomeVCILogo is viewable.
      If I change the code to put brackets around the variable:  (WelcomeVCILogo.data)  the program compiles and executes but nothing happens.  The value of .data does not change.
      In the flex builder environment, it does not autosense when I place the dot at the end of  WelcomeVCILogo to show a list of available properties.
      Note this is not the application level - it is an offspring.
      What is the proper syntax to resolve the image id at this level?
        • 1. Re: .mxml .as syntax question
          Gregory Lafrance Level 6
          mx.core.Application.application.WelcomeVCILogo.data = VCIConfigurationData.Image;
          or
          parentApplication.WelcomeVCILogo.data = VCIConfigurationData.Image;
          or
          parentDocument.WelcomeVCILogo.data = VCIConfigurationData.Image;
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance
          www.ChikaraDev.com
          Flex Development and Support Services
          • 2. Re: .mxml .as syntax question
            BoydMills Level 1
            All three ways of doing it compile and execute
            but all generate the error:
            ReferenceError: Error #1069: Property WelcomeVCILogo not found on VCI and there is no default value.
            at com.vcicontrols.gui::LoginBase/GetConfigurationResult()[C:\from luc 4 point\VCI\src\com\vcicontrols\gui\LoginBase.as:151]
            at flash.events::EventDispatcher/dispatchEventFunction()
            This is frustrating because WelcomeVCILogo can be displayed in the "variables" debug display pane as this.WelcomeVCILogo.
            But I cannot compile this.WelcomeVCILogo !!!!!!!!!!!!!!!!!!
