1. Re: Publishing a project containing a Flash video
Captiv8r Dec 18, 2009 8:12 AM (in response to asebree)Hi there
Are you possibly meaning RoboHelp 8 and combining Captivate 4 with it?
Have you ensured that you copied the FLV to the same location as the Captivate file?
Cheers... Rick
Helpful and Handy Links
Captivate Wish Form/Bug Reporting Form
2. Re: Publishing a project containing a Flash video
ScottPakis Jan 12, 2010 2:00 PM (in response to asebree)You're working in Captivate 8? We're only up to CP4!
If it's indeed a conflict between the video and captivate it could be the video was published using flash player 10 but you're publishing your CP file at 9. Trying publishing at Flash player version 10 and see what happens.
3. Re: Publishing a project containing a Flash video
asebree Jan 13, 2010 7:17 AM (in response to ScottPakis)Sorry! That was a typo. I'm working in Captivate 4.
I tried publishing in Flash Player 10 and this time the slide did not disappear all together, but the video still did not play.
I received some other feedback suggesting I compress the video into a Shockwave Flash Object before importing it. I'm not sure how to do this - any ideas?
Andrea Sebree | Training Specialist
MailExpress
7803 Southland Blvd, Ste 202 | Orlando, FL 32809
O: 407.852.9449 | F: 407.852.9450 | M: 407.256.3539
asebree@mailexpressinc.com | www.mailexpressinc.com
4. Re: Publishing a project containing a Flash video
ScottPakis Jan 13, 2010 9:55 AM (in response to asebree)Perhaps it would be good to back up a bit to see exactly what kind of media you have.
Obviously a Captivate 4 file
And
A video file. Rick assumed this is .FLV, please confirm.
Your feedback to convert to shockwave flash isn't helpful. If you have a .FLV maybe they suggest convert to .swf? Sounds like someone is fishing for a solution.
If possible if you could provide us with the files or some scaled down example I could shead some light on what's going on.
5. Re: Publishing a project containing a Flash video
asebree Jan 13, 2010 11:34 PM (in response to ScottPakis)It is a .flv file. I have been unable to send the .flv file to anyone because of its size. I can send a few slides from the captivate file including the one containing the video if that will help. I attached the published version here - not sure if attachments work in the forum, if not let me know and I'll email it. The video is about 3/4 the way into the file - after the slide titled "Packing". This copy was published to be compatible with Flash 10.
MailExpress
6. Re: Publishing a project containing a Flash video
ScottPakis Jan 14, 2010 9:36 AM (in response to asebree)In order to investigate you'll need to provide the files. There's a website yousendit.com that allows you to transfer files up to 100 MB for free, of if you have a FTP server you can upload and send the link.
7. Re: Publishing a project containing a Flash video
asebree Jan 15, 2010 8:06 AM (in response to ScottPakis)I can send the files through the yousendit.com site. Can you give me your email for me to send them to you?
MailExpress
8. Re: Publishing a project containing a Flash video
niamhsile Jan 20, 2010 8:21 PM (in response to asebree)This is a guess based on my experience exporting CP4 to flash but it may help...
Could it be an actionscript version problem? CP4 creates AS2 projects with AS2 preloaders as standard. If the flv has actionscript 3 in it this could be an issue. In the publish setting change the actionscript version and select an appropriate corresponding preloader (I've found that CP4 does not reliably select an appropriate preloader so do it manually in Publish Preferences > Start and End).
Conversely you may be using AS3 and the flv AS2... same solution applies
Hope this helps!
