This content has been marked as final.
Show 1 reply
1. Re: XML Tables without aid:trows
TurtleCruiser Dec 18, 2009 11:30 AM (in response to chapmanga)I believe the trows and tcols attributes are required. InDesign uses the dimensions to create the table, and then tries to fill it using the subsequent cell elements.
If you have an existing tagged skeleton table that InDesign can flow/merge the XML import into instead, you may be able to get away with not specifying the table size. For example, a 1x3 empty table that's tagged, which, after import, it may become 1x3, 2x3, or 3x3, and so on.
