3 Replies Latest reply on Dec 18, 2009 10:37 AM by miguel8312
    flex application with sql oracle backend.
    miguel8312 Level 3
      Hello everyone im a real noob on flex builder , but im not a noob to programing i
      have several years experience building web apps with plsql , .net, java, and s
      o forth .
      here is my question it looks like for every example I've seen where i would like to used flex builder to make a call to an oracle database  i need to use a  web service or an http service.
      I'm i right? if it is i just cant believe it!!! with asp.net you can make an odbc connection or used an oracle API , or oledb i mean with other languages you can do this right in the application. same with java, classic asp...
      is anyone else doing this withouth a web service if you are can you please help a young noob i know there is got to be something im missing.
      thanks in advance
      Miguel
        • 1. Re: flex application with sql oracle backend.
          msakrejda Level 4
          Flex is more like JavaScript than like .NET or Java (i.e., it runs in the user's web browser). As far as I know, you cannot connect directly to Oracle from JavaScript, and in most situations, allowing this would present serious security problems (your database server is typically not accessible directly by your end-users).
          • 2. Re: flex application with sql oracle backend.
            pauland Level 4
            You have to consider where flex is running - the client. Where is Oracle?  The server. Now consider that the two need to communicate over the network - that's why Flex doesn't directly call Oracle - that and the fact it would be a security problem since flex applications don't behave like html page based applications.
            • 3. Re: flex application with sql oracle backend.
              miguel8312 Level 3
              thank you guys i guess thats what im confused about. if flex application only run
              on the client this makes alot of sense. does anyone have an example of how to get this done? I like to use flex builder because of its Rich user interface but it looks like I'm giving up functionality.
              Miguel
