2 Replies Latest reply on Dec 21, 2009 1:16 PM by Niro_kal
    passing array from coldfuison to as3
    Niro_kal
      hay all
      im new at CF and i'm traying to pass an array (list of languages form mySql) aealy simple one, my function looks like that:
      <cfcomponent>
      <cffunction name="get_languages_pagingUtils" access="remote" returntype="Array" >
      <cfset var arrResult = arrayNew( 1 ) >
      <cfquery name="languages">
      SELECT language_name,native_name
      FROM languages
      </cfquery>
      <cfreturn arrResult>
      </cffunction>
      </cfcomponent>
      on the as3 side i have this:
      the function that call the old fusion function-
      public static function getData():void
      var nc:NetConnection;
      nc = new NetConnection();
      nc.connect("http://localhost:8500/flashservices/gateway/");
      nc.call("paging-debug.cfc.pagingService.get_languages_pagingUtils", new Responder(onResult, onError));
      and the result function:
      public static  function onResult(result:Array):void
      trace("result = ", result as Array)
      i have tray to find all kind of tutorials but no success there..
      i'll be happy for sum halp
      thanks..
        • 1. Re: passing array from coldfuison to as3
          rottmanja
          This is not the best place to post this, but I hope this helps.
          You can use a simple remote object for this.
          index.mxml
              <mx:RemoteObject
                  destination="ColdFusion"
                  source="paging-debug.cfc.pagingService.get_languages_pagingUtils"
                  endpoint="http://localhost:8500/flashservices/gateway/" (try this insead http://localhost:8500/flex2gateway/)
                  id="roLanguages"
                  showBusyCursor="true">
                  <mx:method name="get_languages_pagingUtils" result="onResult(event)" />
              </mx:RemoteObject>
          your actionscript
          import mx.rpc.events.ResultEvent;
          import mx.utils.ObjectUtil;
          public function getData():void{
               roLanguages.get_languages_pagingUtils()
          private function onResult(event:ResultEvent):void{
               trace(ObjectUtil.toString(event.result);
          • 2. Re: passing array from coldfuison to as3
            Niro_kal Level 1
            thanks for your answer..
            i thought that it's not the place for it..
            but any way this is steel not helping me cose im trying to pass the array to
            a class and not to flex - (when i'm dooing it in flex its all good just like you say)
            thanks again.
