I'm using Fireworks CS3 (Windows).
I started with 3 elements - logo, "WISR" text and "Ads" text - and created a PNG file (see below and attached files).
I'm trying to change the background behind the logo and the "WISR" text to be transparent but it will not change - it is stuck on White (FFFFFF).
Note: The area behind the "ads" text is set to transparent.
Any ideas on how to change the entire background to transparent??
CRS
Try see if it is ok now with the attached file. All I did was remove the white background with the magic wand.... it should be all trasparent now
Google search for "Mac's Remove White" filter, and install it in your plugin's folder. You'll never struggle with removing white backgrounds from images again.
Thanks!
CRS
