3 Replies Latest reply on Dec 31, 2009 10:52 AM by Anne Tuohy
    Checking user input
    Khadiga Mohamed
      I want the user to use an editable zone and type one word. I want Director to check the answer and decide to move on to a certain frame if the answer is correct. To make this easier to understand let's consider this. I want the user to see a question on the screen saying something like "What is the capital of France?" I want the user to type "Paris" and then the answer can be checked. How can all this be designed in Director? Thanks for your help.
        • 1. Re: Checking user input
          Sean_Wilson Adobe Community Professional
          See my response on the other forum you posted to
          • 2. Re: Checking user input
            Anne Tuohy
            this code workedfor me
            when user types in a word presses the enter key
            the event calls a moveon method. you can call moveon anyname  you like
            input is a blank textfield if the answer is right the word well done is inserted into the textfield. you can also have a second textfield to put the words welldone or try again. You can also use an text input box to do this , but I could lnot change the font size that way.
            Hope it worksfor you.
            on keydown
              if the key = return or the key = enter then
                moveon
              else
                pass
              end if
            end
            on moveon me
              if member("input").text = "house" then
                member ("input").text = "Well done!"
              else
                member ("input").text = "try again"
              end if
            end
            on keydown
                moveonhorse
              else
                pass
              end if
            end
            • 3. Re: Checking user input
              Anne Tuohy Level 1
              you can leave
              out the last seven lines of the code that is a mistake. hope im not confusing you
