3 Replies Latest reply on May 4, 2017 4:33 AM by Mahesh_JW
    do scirpt for copy file
    Mahesh_JW Level 1
      for(var a=0;a<myDoc.links.length;a++){
                  var  f = File(myDoc.links[a].filePath);
                  var fname = f.name;
                  copyPasteScript = "tell application \"Finder\"\r";
                 copyPasteScript += "copy file \""+myDoc.links[a].filePath+"\" to folder \""+ArtFolder+"\"\r";
                  copyPasteScript += "end tell";
                  app.doScript(copyPasteScript, ScriptLanguage.applescriptLanguage);
                  var f2 = File(ArtFolder+"/"+fname);
                  myDoc.links[a].relink(f2);
                  myDoc.links[a].update();
      it throws error in the highlighted line what to do....
        • 1. Re: do scirpt for copy file
          [Jongware]-9BC6tI Level 4
          "An error". Care to tell what the error is? That might help us to help you.
          Looking at your script, I would guess "Unknown variable: ArtFolder".
          • 2. Re: do scirpt for copy file
            Muppet Mark-QAl63s Level 4
            Why NOT use ID's links copyLink to folder? No need to involve AppleScript and Finder…
            #target indesign
            var userHome = Folder('~').fsName.toString();
            var linksFolder = userHome + '/Desktop/ID Links/';
            myLinks = CreateFolder(linksFolder);
            main();
            function main() {
            if (app.documents.length == 0) {
            alert('Please have an "Indesign" document before running this script.');
            return;
            docRef = app.activeDocument;
            with(docRef) {
            for (var i = 0; i < links.length; i++) {
            links[i].copyLink(myLinks);
            function CreateFolder(Directory) {
            var folderPath = new Folder(Directory);
            if (folderPath.exists == false) {
            folderPath.create();
            return folderPath;
            • 3. Re: do scirpt for copy file
              Mahesh_JW Level 1
              var myParameters = [File(myFile),Folder(myFolder)];
              //copy
              var myAppleScript = "tell application \"Finder\"\rtry\rcopy file (item 1 of arguments as string) to folder (item 2 of arguments as string)\rend try\rend tell";
              //move
              var myAppleScript = "tell application \"Finder\"\rtry\rmove file (item 1 of arguments as string) to folder (item 2 of arguments as string)\rend try\rend tell";
