1 Reply Latest reply on Dec 21, 2009 8:08 AM by kglad
    Button & print AS
    jmdewi Level 1
      I've created a button and want the action to print the page I put the .swf on.
      I put in the action 'window.print();' on it's own layer called 'Actions'.  I am getting the following Compiler Error: "Statement must appear within on handler".
      Within the parantheses of the action, it calls for a target/type and I'm not sure what I'm supposed to input here.
      Any help is appreciated!  Attached is the .fla file.
        • 1. Re: Button & print AS
          that error message means your code should be attached to a frame, not an object.
          if you want a button to trigger that code use something like:
          but i'm not sure window.print() will work unless you have an object named window that has a print() method.
