2 Replies Latest reply on Dec 21, 2009 10:50 AM by Francisc
    Reading XML Dynamically + After exporting
    vksvicky Level 1
      I have a standalone program written and I read the XML file like
      <mx:XML id="dataTiny"
                  source="xml/dataTiny.xml" />
      When I export from the builder, even the XML file content gets embedded.
      What I need is to read the XML file from a particular location and if the file is not there, show an error.
      How can I achieve this?
        • 1. Re: Reading XML Dynamically + After exporting
          vksvicky Level 1
          Also I have a lot of dependency I've created with the id 'dataTiny', how can I assign the data back to that if there is a different mechanism for reading XML?
          • 2. Re: Reading XML Dynamically + After exporting
            Francisc Level 3
            I would use HTTPService. Here's an example of `how-to`:
            <mx:Script>
            <![CDATA[
            import mx.controls.Alert;
            import mx.rpc.events.FaultEvent;
            import mx.rpc.events.ResultEvent;
            import mx.collections.ArrayCollection;
            private var myRetrivedData:ArrayCollection;
            private function getXMLData():void
                 httpService.send();
            private function httpFaultHandler(event:FaultEvent):void
                 Alert.show("Cannot load XML file.","Error");
            private function httpResultHandler(event:ResultEvent):void
                 myRetrivedData=event.result.elements.element;
            </mx:Script>
            <mx:HTTPService id="httpService" url="someXMLFile.xml"
                 fault="httpFaultHandler(event)" result="httpResultHandler(event)"/>
            <mx:DataGrid id="myDataGrid" dataProvider="{myRetrivedData}"/>
            Hope this helps.
            To change the source dynamically do this: httpService.url="http://www.mysite.com/xmlFeed.xml" or httpService.url="xmlFeed.xml" from a function.
