3 Replies Latest reply on Dec 27, 2009 11:54 AM by DennisTh
    How to "anchor" an UICompoment object REFdn6025643069
    DennisTh Level 1
      I do the follow:
            var d:PanelGradient=new PanelGradient(0,0,stg.width/2,stg.height/2,30,30,stg.width/2*1.5,stg.width/2*1.5);
            d.setStyle("right",10);
            d.setStyle("bottom",10);
            addChild(d); // to main Stage
      In the above code, setting the “right” and “bottom” styles, I expect in case of resizing the browser, the PanelGrandient object to be anchored in the right bottom corner…. Something that it doesn't happen.
      What I do wrong?
      p.s. The PanelGradient extends the UIComponent and in real is a container of a Shape with a matrix.
      Dennis
        • 1. Re: How to "anchor" an UICompoment object REFdn6025643069
          Flex harUI Adobe Employee
          If PanelGradient sets its x/y/width/height in the constructor, I'm not sure the left/bottom constraints will win.
          Also, make sure PanelGradient will update the Shape when resized.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: How to "anchor" an UICompoment object REFdn6025643069
            DennisTh Level 1
            Hi, thank you for your reply.
            I do not initialize the x, y, width or height of the UIComponent, but I do this initialization on the Child of this container.
            In precise here is the code... maybe helps you...
            package myGraphics
              import flash.display.GradientType;
              import flash.display.Shape;
              import flash.display.Sprite;
              import flash.geom.Matrix;
              import mx.core.UIComponent;
              public class PanelGradient extends UIComponent //Sprite
              //classic use: PanelGradient(0,0,stg.width,stg.height,30,30,stg.width*1.5,stg.width*1.5)
                public function PanelGradient(x:int,y:int,width:int,height:int,illuminancex:int,illuminancey:int,illumina ncewidth:int,illuminanceheight:int)
                  super();
                  var myShape:Shape = new Shape();
                  var gradientBoxMatrix:Matrix = new Matrix();
                  gradientBoxMatrix.createGradientBox(
                    illuminancewidth,                      //width
                    illuminanceheight,                     //height
                    0,                                     //rotation
                    illuminancex-(illuminancewidth/2)+x,     //x of illumine
                    illuminancey-(illuminanceheight/2)+y  ); //y of illumine
                  myShape.graphics.beginGradientFill(GradientType.RADIAL, [10395294, 3487029], [1, 1], [0, 255], gradientBoxMatrix);
                  myShape.graphics.drawRect(x, y, width, height); //x, y, width, height
                  myShape.graphics.endFill();
                  addChild(myShape);
            • 3. Re: How to "anchor" an UICompoment object REFdn6025643069
              DennisTh Level 1
              Hello... is anybody home?!?
