0 Replies Latest reply on Dec 21, 2009 1:10 PM by Chet Haase
    [svn:fx-trunk] 13126: Fix to bug when ending Parallel effects with Resize effect children.
    Chet Haase Level 3
      Revision: 13126
      Revision: 13126
      Author:   chaase@adobe.com
      Date:     2009-12-21 13:10:02 -0800 (Mon, 21 Dec 2009)
      Log Message:
      Fix to bug when ending Parallel effects with Resize effect children. There were three problems here:
      - Resize effects were being mis-ordered inside of the Parallel, causing them to be ended out of order. If any of these effects were order-dependent, this caused a problem in ending at the right values.
      - Animation usually populates the values of an effect lazily, just when it actually starts. So an effect with a startDelay would not get real from/to values until the startDelay elapsed. This meant that an effect that was end()'d prematurely would send out a bogus final value because it had not yet been populated with real from/to values.
      - Repeating/reversing animations were not being end()'d at the proper beginning/end value, based on their repeatCount (they would always end at the full durection of whatever iteration they were currently in).
      QE notes: None
      Doc notes: None
      Bugs: SDK-24755
      Reviewer: Jason
      Tests run: Checkintests, Mustella spark/effects, mx/effects
      Is noteworthy for integration: Yes: reported in Catalyst bug bash
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24755
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/ParallelInstanc e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
