9 Replies Latest reply on Dec 22, 2009 11:36 AM by the_wine_snob
    Low Quality on Imported AVI
    artbyruss Level 1
      This is not a premiere elements issue, but I am using the software to create a project.  My problem deals with the quality of the video I took on vacation.  I inadvertently place the camera in a low resolution mode.  Although the video can be seen using Realplayer or Windows media player, the quality is only accepatble for a very small screen.  When I transport the video to my project, the quality is unacceptable.  Is there anyway I can improved the quality of the original video?
      The AVI was transfered from a file on my PC, which was downloaded from a SD flash card on a Canon A650 camera in the compact mode (this was the mistake).  I was hoping to make a DVD of our trip combining video, JPEGs, and music.  Out of the twenty some video clips I took on the Canon, only the first two are usable.  Somehow I change the quality of video clip and the lower qulality was not noted until I returned home and started looking at the video on my PC.
        • 1. Re: Low Quality on Imported AVI
          Well, technically it's not possible to get more out of something than you put it, so you can't improve the quality.
          But you'll get the best results if you use programs that best work with the codecs your video uses.
          I'd recommend, for still camera video, that you work with Windows MovieMaker. It handles the codec well and produces very good results.
          If, after importing the video into MovieMaker, you want to work with it or create a DVD from it in Premiere Elements, you can output the video as a DV-AVI, the universal language of PC based video editors, per the FAQs to the right of this forum.
          http://forums.adobe.com/thread/415317?tstart=0
          • 2. Re: Low Quality on Imported AVI
            the_wine_snob Level 9
            To tie things together, THIS was the earlier post to the Tips & Tricks section, and my comment.
            Now, one strike against the footage is that it's MJPEG AVI at 640 x 480, 30 fps. Not sure which MJPEG CODEC you have, but you might get an improvement from either the Morgan, or the MainConcept CODEC's. Both get very high marks. Some others do not, and the footage that goes through them looks bad no matter what.
            However, this might be some good news. When one is viewing AV files on their computer, they are usually looking at a progressive image at higher resolution than a DVD-Video, hooked to a TV.
            The first thing that I'd do would be to Import one of the files as a test. Then, I'd output that to a DVD RW (Rewritable) disc, and put it in a set-top player. Test that footage there. Just make it an Auto-play DVD-Video. The reason for the RW is so you can test multiple times. Not sure if PrE will erase RW DVD's, but the free burning utility, ImgBurn, will.
            After you have viewed the material on a TV, through a set-top player, make note of what you find offensive about the footage. That will lead us to make suggestions on ways to improve it in PrE, with either Effects, or with other treatments.
            Also, if you can upload some of the footage, just enough to show what you see as problems, we can download it, and experiment with it.
            • 3. Re: Low Quality on Imported AVI
              artbyruss Level 1
              Hunt, thanks for your time, but burning a DVD didn't improve the  quality.
              I was unable to have any success with the two websites.   Guess I have
              learn my lesson to always check the accuracy of ones  settings.
              Russ
              In a message dated 12/21/2009 7:18:46 P.M. Eastern Standard Time,
              forums@adobe.com writes:
              To tie  things together, http://forums.adobe.com/thread/542623?tstart=0
              improvement from either the http://www.morgan-multimedia.com/, or the
              *http://www.mainconcept.com/site/prosumer-products-4/motion-jpeg-codec-785/information-797
              .html*  CODEC's. Both get very high marks. Some others do not, and the
              other  treatments.
              Good  luck,
              • 4. Re: Low Quality on Imported AVI
                artbyruss Level 1
                I did try Moviemaker and it seemed to improve the quality a little, but not
                enough.  Thanks for your idea and time.  Have a Merry Christmas.
                Russ
                In a message dated 12/21/2009 6:59:46 P.M. Eastern Standard Time,
                • 5. Re: Low Quality on Imported AVI
                  For clarification, were the Morgan and MainConcept sites down, or that the MJPEG CODEC from neither improved your footage?
                  If the latter, then you probably already have a pretty good MJPEG CODEC installed.
                  Now, we seem to have reached one dead-end - improving the footage via Import. That is not all there is. Would it be possible to post a screen-cap of your footage in the Timeline, with the CTI (Current Time Indicator) over one of these poor Clips, and the Program Monitor sized up to clearly see the Clip in it? Then, please point out the aspects that you find objectionable. We may, or may not, see all of the issues, so that's why your words will be important.
                  There could well be Effects and techniques that will improve the footage. It might fall sort of what you hope for, but we should be able to come up with a few things to make it better.
                  • 6. Re: Low Quality on Imported AVI
                    artbyruss Level 1
                    Let me see if I understand your instructions.  I am not very familiar  with
                    Premiere Elements.  What do you mean posting a screen-cap of your  footage
                    in the Timeline?  Do you want me to more one of the clips to the  timeline?
                    Is the Current Time Indicator the device that has a top that  looks a
                    little bit like an arrow and a red line extending down?  If so, the  Program
                    Monitor reflects an image that is not clear.  It looks like each  pixel is
                    covering too much area thereby not giving the desired clarity.
                    Russ
                    In a message dated 12/22/2009 11:12:05 A.M. Eastern Standard Time,
                    installed.
                    be  important.
                    Good  luck,
                    • 7. Re: Low Quality on Imported AVI
                      Russ,
                      Sorry for getting ahead of you.
                      What I am suggesting is that you set up your PrE editing screen (the GUI - Graphic User Interface) with one of these "bad" Clips on the Timeline. Place the CTI (Current Time Indicator w/ the Edit Line) over that Clip, so that it will show in the Program Monitor. You might want to click-drag on the various Panels, and also zoom in on your Timeline a bit, so that the important parts are large enough to see. Once you have this set up, then do a screen-cap of that GUI.
                      This can differ a bit, depending on one's computer, their image editing programs, and even their keyboard, but here are the general instructions:
                      1.) when all is set up in PrE, showing things clearly, one would Copy that image from the computer's monitor to the Clipboard. On my laptop, this is done by pressing Ctrl+PrtSC (Print Screen) key. On other keyboards, the CTRL modifier key is not necessary. Also, the exact name of the key for "Print Screen" might be slightly different. Mine is "PrtSc," but yours could be something like "PrntScr." This takes a snapshot of what is displayed on your computer's monitor.
                      2.) I use Photoshop (PS) as my image editing software, but PSElements is about the same. If one has another image editing program, they might need to read up on how to do this next step. MS Paint, plus others, should be able to do similar, though more steps, or fewer steps, might be required.
                      In PS, I do File>New Image (Ctrl+N) and PS will offer to create this New Image sized to the image in the system's Clipboard, which I accept. This New Image opens, and all I have to do is hit Ctrl+V (Paste) to get my screen-cap from the Clipboard and into my New Image as a New Layer. Then, I will Crop, if necessary, annotate the image to point out aspects that I want people to look at, then will do a Save, choosing .PSD to maintain any Layers. Then, I choose Flatten to collapse the Layers, and do a Save_As, choosing JPEG @ a quality setting of 8-9.
                      3.) back in the forum editing screen, I look to the Toolbar at the top of the page. In the lower-middle, there is a little "camera" icon. That allows me to attach the JPEG image into the body of my Reply.
                      Here's an example of my NLE setup, pretty much as I am suggesting:
                      Hope that this helps,
                      • 8. Re: Low Quality on Imported AVI
                        artbyruss Level 1
                        Hunt, I really am having a hard time trying to understand your
                        instructions.  I downloaded the premiere editor to see if that would help  with the
                        terminology, but it didn't, at least not to the extend I need.  I  guess I just
                        will not use the video.  I still have 300 JPEGs to use so that  should give
                        me enough to work with for my project.  Thanks for your  help.  You need to
                        spend your time and expertise on people that have a  better understanding
                        than me.  Thanks again and have a Merry  Christmas.
                        Russ
                        In a message dated 12/22/2009 12:50:03 P.M. Eastern Standard Time,
                        Russ,
                        computer's monitor.
                        http://forums.adobe.com/servlet/JiveServlet/showImage/17348/Screen-cap_01.jp
                        g
                        • 9. Re: Low Quality on Imported AVI
                          Russ,
                          Sorry that I was still using too much jargon, or just not being clear.
                          One offer that I can make is if you wanted to send me, say a short Clip that you are not happy with, and tell me what you find objectionable, I'll load it up and see if there are some Effects, or techniques that would benefit the footage.
                          My POP server can handle large attachments. You can e-mail me at infoAThuntphotoDOTcom. (Obviously, the AT = @ and the DOT = .). Cut out, say a 1 min. section, and then Export/Share to a DV-AVI file. Attach that to the e-mail. I'll see what can be done, and if successful, will tell you step by step what I did, so you can follow along.
