2 Replies Latest reply on Dec 20, 2010 11:56 AM by TᴀW
    Hyperlink to hyperlinkTextDestination in external document
    bcmartinez4
      I have an InDesign book (.indb) with one document for each chapter, plus one document for the table of contents.  I'm trying to automate the process of making a hyperlink from each item in the TOC to a hyperlinkTextDestination I've already added to each of the other documents.  This way, when I Export for Digital Editions, I have copy of my TOC with hyperlinks to each chapter.
      My TOC is just a simple page with a textFrame, with each link on its own line, like this:
      Chapter 1
      Chapter 2
      Chapter 3
      Can anyone please describe how to do this in JavaScript?  Thanks in advance for any help.
        • 1. Re: Hyperlink to hyperlinkTextDestination in external document
          bcmartinez4 Level 1
          I was finally able to figure out the problem, and since I haven't been able to find anything on this specific topic elsewhere, I'll post it here for posterity.
          The main problem was that my destination document was closed when I tried to create the hyperlink.  I stored the hyperlinkTextDestinations for each doc into an array so I could call them later, and then closed the document so the script could do other stuff.  Anyway, here are the code snippets pertinent to hyperlinking to external hyperlinkTextDestinations:
          var mydocs = bookPath.getFiles('*.indd');  // Folder containing each chapter's document
          var hyperlinkDestinations = new Array;
          for (i=0; i<mydocs.length; i++){
            var thisDoc = app.open(mydocs[i]);
            // Add hyperlink destinations
            var newDestination = thisDoc.hyperlinkTextDestinations.add(thisDoc.textFrames[0].insertionPoints[0]);
            hyperlinkDestinations.push(newDestination);
            thisDoc.close();
          Then in my TOC document:
          var tocdoc = app.activeDocument;
          var toc = tocdoc.textFrames[0].paragraphs;
          for (i=0; i<toc.length; i++) {
            // My TOC list is in the same order as my files are...
            var myHyperlinkTextSource = tocdoc.hyperlinkTextSources.add(toc[i]);
            var tempDoc = app.open(mydocs[i]); // Make sure doc is open before referencing hyperlinkTextDestination
            var myHyperlink =
          tocdoc.hyperlinks.add(myHyperlinkTextSource, hyperlinkDestinations[i]);
            tempDoc.close();
          This isn't my exact code (I just copied out bits and pieces), so I haven't tested it.  If anyone knows a better way of doing this, feel free to chime in.
          I've taken a pretty deep dive into InDesign scripting and this forum has been incredibly helpful, so I hope this pays it forward, at least a little.  Thanks!
          • 2. Re: Hyperlink to hyperlinkTextDestination in external document
            TᴀW Adobe Community Professional & MVP
            bcmartinez,
            Thanks for posting this. It's almost exactly a year later to the day (weird!), and I've run into the identical issue you write about (here's the thread: http://forums.adobe.com/message/3353050#3353050) Hope your solution works for me as well...
            Ariel
