0 Replies Latest reply on Dec 22, 2009 10:15 AM by jmurphy67
    [svn:fx-trunk] 13157: -revert a portion of my previous change so that asdoc will work properly - moved the proprietary automation swcs back into the libs directory .
    jmurphy67 Level 1
      Revision: 13157
      Revision: 13157
      Author:   jimurphy@adobe.com
      Date:     2009-12-22 10:15:18 -0800 (Tue, 22 Dec 2009)
      Log Message:
      -revert a portion of my previous change so that asdoc will work properly - moved the proprietary automation swcs back into the libs directory.  the automation projects swcs will still get compiled into the automation directory.
      This should fix the build
      QE notes: make sure packaging is correct
      Doc notes: no
      Bugs: no
      Reviewer:no
      Tests run: checkintests, doc targets run
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/build.xml
          flex/sdk/trunk/frameworks/projects/automation/build.xml
          flex/sdk/trunk/frameworks/projects/automation_air/build.xml
          flex/sdk/trunk/frameworks/projects/automation_dmv/build.xml
          flex/sdk/trunk/frameworks/projects/automation_flashflexkit/build.xml
          flex/sdk/trunk/frameworks/projects/automation_spark/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/libs/automation_agent.swc
          flex/sdk/trunk/frameworks/libs/qtp.swc
          flex/sdk/trunk/frameworks/libs/qtp_air.swc
      Removed Paths:
          flex/sdk/trunk/frameworks/libs/automation/
