0 Replies Latest reply on Dec 22, 2009 12:24 PM by Hodmi
    Destination cannot be introspected because itemClass is not set
    Hodmi Level 4
      I'm trying to access a LCDS 3 hibernate connection using the new Connect to Data/Service wizard in Flash Builder 4 (beta 2).
      On the LCDS side I have my database set, a java class deployed, the hibernate configuration file set, hibernate mapping file set and a destination created.  It all looks good from that side.
      On the Flash Builder side;  I created a new Flash Project using LCDS and pointed it to the right server.  When I go through the Connect to Data/Service wizard Builder does find my destination and it fills in all of the fields in the dialog box.
      When I click Finish however I get an Introspection Error dialog box that says: "Destination (destinationID=thoughtBox.hibernate) cannot be introspected because itemClass is not set".  The item-class tag is set in the data-management-config.xml file:
      <destination id="thoughtBox.hibernate">
              <properties>
                  <use-transactions>true</use-transactions>
                  <source>flex.data.assemblers.HibernateAssembler</source>
                  <!--<item-class>flex.samples.contact.Contact</item-class> -->
                  <scope>application</scope>
                 <item-class>thoughtBox.ThoughBoxTile</item-class>
                  <metadata>
                      <identity property="id"/>
                  </metadata>
                  <network>
                      <paging enabled="false" pageSize="10"/>
                  </network>
                  <server>
                       <hibernate-entity>thoughtBox.ThoughBoxTile</hibernate-entity>
                  </server>
              </properties>
          </destination>
      Everything looks okay, but it just doesn't want to pick up the item-class tag.
      Any thoughts?
