0 Replies Latest reply on Dec 22, 2009 2:40 PM by Paul Reilly
    [svn:fx-trunk] 13169: * Fixes for two FB issues and two regressions caused by recent fixes.
    Paul Reilly Level 1
      Revision: 13169
      Revision: 13169
      Author:   preilly@adobe.com
      Date:     2009-12-22 14:39:59 -0800 (Tue, 22 Dec 2009)
      Log Message:
      • Fixes for two FB issues and two regressions caused by recent fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-24708, SDK-24668, SDK-24827, SDK-24829
      Reviewer: Corey
      Tests run: checkintests, com.adobe.flexbuilder.project JUnit tests
      Is noteworthy for integration: Yes, fixes two FB issues
      Code-level description of changes:
        modules/compiler/src/java/flex2/tools/oem/Library.java
        modules/compiler/src/java/flex2/tools/Compc.java
        modules/compiler/src/java/flex2/tools/Fcsh.java
        modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
          Modified calls into SwcAPI's setupClasses() and
          setupNamespaceComponents() to pass in the SourceList.
        modules/compiler/src/java/flex2/tools/VersionInfo.java
          Added null check to getBuild().
        modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          Modified compile() to only add elements of "classes" to "sources"
          if not already contained.  This covers the case of a Source being
          in the SourceList and the manifest.
        modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          Modified setupClasses() and setupNamespaceComponents() to check the
          SourceList before the SourcePath when looking up sources.
        modules/compiler/src/java/flex2/compiler/SourceList.java
          Made getPaths() public.
        modules/compiler/src/java/flex2/compiler/CompilationUnit.java
          Modified setState() to skip disconnecting the root's Logger.  This
          fixes SDK-24827 and SDK-24829.
        modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
          Added sourceList variable, modified procressSources() to
          initialize it, and modified init() to recursively store a
          timestamp for each path in the SourceList.  This fixes SDK-24708.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24708
          http://bugs.adobe.com/jira/browse/SDK-24668
          http://bugs.adobe.com/jira/browse/SDK-24827
          http://bugs.adobe.com/jira/browse/SDK-24829
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourceList.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/VersionInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMReport.java
