3 Replies Latest reply on Dec 23, 2009 11:33 PM by chanchac
    XSLT Parameters in workbench
    chanchac
      Hello,
      I have a variable in my process of type string called "MyVariable"
      I want to reference this variabale in an XSLT file as a parameter.
      How do I do that?
      Below is first attempt, but it doesnt seem to work:
      <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns:xfa="http://www.xfa.org/schema/xfa-data/1.0/" xmlns:dd="http://ns.adobe.com/data-description/">
      <xsl:param  name="thePath">{$ /process_data/@MyVariable $}</xsl:param>
      <xsl:output method="xml" version="1.0" encoding="UTF-8" indent="yes"/>
      <xsl:template match="/" xmlns:cic="http://cic.gcms.mel/">
        <cic:applicationDetails xmlns:cic="http://cic.gcms.mel/" xmlns:arr="http://schemas.microsoft.com/2003/10/Serialization/Arrays">
         <cic:DependentApplicant>
          <cic:FamilyName>
           <xsl:value-of select="$thePath/Child1Name"/>
          </cic:FamilyName>
          <cic:Age>
           <xsl:value-of select="$thePath/Child1Age"/>
          </cic:Age>
          <cic:Gender>
           <xsl:value-of select="$thePath/Child1Gender"/>
          </cic:Gender>
         </cic:DependentApplicant>
        </cic:applicationDetails>
      </xsl:template>
      </xsl:stylesheet>
      Lil help?
        • 1. Re: XSLT Parameters in workbench
          Scott Brodersen Adobe Employee
          If the input property of the service operation can be expressed as a Template
          value, then you can use parameters. You need to enclose the xpath expression inside {$   $}, such as
          {$/process_data/@strvar$}
          or
          <xsl:value-of select="{$thePath/Child1Age$}"/>
          http://livedocs.adobe.com/livecycle/8.2/wb_help/000210.html
          Hope that helps (at least a lil bit)
          scott
          • 2. Re: XSLT Parameters in workbench
            g5spark Level 1
            I have the same problem and tried what was suggested with no luck.  Here is my
            xslt.
            <?xml version="1.0" encoding="UTF-8"?>
            <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
            <xsl:output method="text" version="1.0" encoding="UTF-8" indent="yes"/>
            <xsl:template match="/">
               <xsl:value-of select="{$ /process_data/@inVar $}"/>
            </xsl:template>
            </xsl:stylesheet>
            where inVar (string) is the name of variable in workbench.
            I get the following error.
            ALC-DSC-000-000: com.adobe.idp.dsc.DSCRuntimeException: Internal error.
            at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:367)
            at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:157)
            at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
            at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
            at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
            at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:342)
            at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:284)
            at sun.reflect.GeneratedMethodAccessor244.invoke(Unknown Source)
            at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
            at java.lang.reflect.Method.invoke(Method.java:592)
            at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
            at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
            at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
            at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
            at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
            at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
            at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:404)
            at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
            at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
            at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
            at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
            at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
            at org.jboss.ejb.Container.invoke(Container.java:960)
            at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
            at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
            at $Proxy207.doRequiresNew(Unknown Source)
            at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
            at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
            at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
            at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
            at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:132)
            at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
            at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:115)
            at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:118)
            at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiv er.java:315)
            at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint. java:138)
            at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java :81)
            at sun.reflect.GeneratedMethodAccessor464.invoke(Unknown Source)
            at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
            at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
            at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
            at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
            at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
            at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
            at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
            at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
            at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
            at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
            at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
            at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
            at sun.reflect.GeneratedMethodAccessor463.invoke(Unknown Source)
            at org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil.java:244)
            at java.security.AccessController.doPrivileged(Native Method)
            at javax.security.auth.Subject.doAsPrivileged(Subject.java:517)
            at org.apache.catalina.security.SecurityUtil.execute(SecurityUtil.java:276)
            at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:162)
            at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:283)
            at org.apache.catalina.core.ApplicationFilterChain.access$000(ApplicationFilterChain.java:56 )
            at org.apache.catalina.core.ApplicationFilterChain$1.run(ApplicationFilterChain.java:189)
            at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:185)
            at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java :43)
            at sun.reflect.GeneratedMethodAccessor462.invoke(Unknown Source)
            at org.apache.catalina.security.SecurityUtil.doAsPrivilege(SecurityUtil.java:218)
            at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:230)
            at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
            at sun.reflect.GeneratedMethodAccessor461.invoke(Unknown Source)
            at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
            at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
            at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.ja va:179)
            at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
            at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
            at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
            at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java: 156)
            at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
            at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
            at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
            at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.ja va:580)
            at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
            at java.lang.Thread.run(Thread.java:595)
            Caused by: java.lang.NullPointerException
            at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:842)
            at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:346)
            ... 110 more
            at com.adobe.livecycle.xslt.XsltTransformer.transform(XsltTransformer.java:126)
            at com.adobe.livecycle.xslt.XsltService.transform(XsltService.java:213)
            at com.adobe.livecycle.xslt.XsltService.transform(XsltService.java:88)
            at sun.reflect.GeneratedMethodAccessor4333.invoke(Unknown Source)
            at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
            at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(Ej bTransactionCMTAdapterBean.java:212)
            at sun.reflect.GeneratedMethodAccessor323.invoke(Unknown Source)
            at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:378)
            at $Proxy207.doSupports(Unknown Source)
            at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:104)
            at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:91)
            at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:21 5)
            at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:57)
            at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
            at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:729)
            ... 111 more
            • 3. Re: XSLT Parameters in workbench
              chanchac Level 1
              So my question still hasnt been answered.  How do you pass an adobe variable as a parameter to an XSLT file??????
              @q5spark: dude do you have to post such a long error message? seriously.
