3 Replies Latest reply on Aug 31, 2007 5:44 AM by Newsgroup_User
    chopping of corners
    chrisgm187 Level 1
      Hi Guys
      I draw a rounded rectangle and want to chop off the four corners and make each corner in to a separate img so there all the same size can any one help please.
        • 1. Re: chopping of corners
          pixlor Level 4
          Set your canvas size to the size of your rectangle
          Zoom in to 300 or 400%
          Set guides at the right places to mark off the corners (double-click on one to set its position numerically)
          Make slices (you can set size and position of slices with the Info palette)
          Export the slices
          • 2. Re: chopping of corners
            MonteKrause Level 1
            why don't you try using one of the other vector or path drawing tools and create any shape your heart desires.
            • 3. Re: chopping of corners
              Level 7
              Try this.
              Once you have your rounded rectangle > drag out another rectangle over the
              top and position it so you can just see the top and bottom edges of your
              original. > Now drag out another rectangle and position it so you can just
              see the left and right edges of your original. > Select both the new
              rectangles you've just created > Modify > Combine paths > Union. > Now
              select your original rectangle and your newly created shape of the two new
              rectangles > Modify > Combine Paths > Punch. This should leave you with the
              four corner sections you want. Finally > select the four sections group >
              Modify > Combine paths > Split.
              Peter
              __________________
              "chrisgm187" <webforumsuser@macromedia.com> wrote in message
              news:fb7ees$12h$1@forums.macromedia.com...
              | Hi Guys
              help please.
